Question about Evenflo Aura Elite Travel System Wedgewood Stroller
The latch that holds my evenflo stoller closed has broken. Where can I get a replacement latch?
  • keno777 Aug 29, 2008
    the side support on the side of the stroller is broken-model 25707507 5/03. this is the part half way between the wheels and top of the seat
    Problem Solver:
  • 9 Answers
You should contact evenflo for a replacement part- or else you can order them if you follow the link - it takes you to the ordering page on their website for replacement parts- https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=5881485a&txSearchDOM=2/4/2004
Posted on May 12, 2008
On my SureRide convertible car seat, the ******** the anchor hooks is to short and the latches will not reach both anchors in my car. I have moved the rear facing seat from the middle of the car to o
I would suggest reading the user manual for the Evenflo SureRide convertivble car seat, which is available here:http://www.evenflo.com/Portals/0/instructions/Inst-SureRide-T65-0911.pdfAnd be sure to contact Evenflo. They can provide the best help for your problem:http://www.evenflo.com/corporate.aspx?id=175
Also, these how-to installation videos may be helpful:
http://www.evenflo.com/support.aspx?id=494
http://www.evenflo.com/support.aspx?id=492
http://www.evenflo.com/support.aspx?id=493
Feb 12, 2013 | Evenflo Symphony Convertible Car Seat ...
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
2003 Toyota Corolla. Trunk won't stay closed. Latch seems to work fine.
must have a broken spring in the latch tha'ts how it works a spring keeps the locking teeth together.replace the latch.
Nov 25, 2010 | 2004 Toyota Corolla
How do i get my hood 2 closed if the latch is broken
You could tempoarly hold it closed with a bungie cord hooked to the hood in the front and allached to a secure place ubder the truck, then get a replacement latch to do the repair
Oct 05, 2010 | 2001 Dodge Ram 1500 Truck 2WD
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Broken latch
Replacement latch can be found at amazon, click here Amazon com mailbox latch and chose needed one. Wish you best of luck. John
May 03, 2009 | Solar Group Black Aluminum Mailbox Post,...
Broken plastic buckle on Chicco Stoller
contact Chico and ask where can you get spare parts, have done this for Britax Excel travel system and the part is being sent out today from Stork Talk in the UK
Nov 21, 2008 | Baby Gear
Need directions on how to fold legs
Hi, I can fix this.
First, on the bottom of the legs, there is a thumb latch, press that all the way down into the hold it is in. do this on all three legs.
Then once that is done turn the whole thing to the left, it should fold in two, on the sides, there are three latchs that go into the hole next to the small legs, those latches secure it in place.....
To unfold, simply press on the holding latches, and pull up.
Good Luck.
Gordon & Shirley
Nov 17, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Acer Latch is broken
On most notebooks, there is a VERY small return spring (smaller than a spring from a ball point pen) on the latch that tends to break.
Apr 20, 2008 | Acer Aspire 5102WLMi Notebook
Replacement Parts
Here is the link to the Replacement Parts ordering page at Evenflo: https://plweb.evenflo.com/replacement_parts.aspx
Feb 22, 2007 | Evenflo Aura Select Travel System -...
Evenflo Aura Elite Travel System Wedgewood Stroller Logo
222 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
