Question about HP Pavilion dv9608ca PC Notebook
How do I fix a backlight problem on my hp pavilion dv9608?
When I power up my laptop, My monitor is black, but I can see a very faint screen when I hold the laptop up to a light. I can hear my laptop running. I hooked an external monitor up to my laptop and the external monitor works fine. My laptops screen is black, could this be a backlight problem? Help???? Jason Green
  • jasongree88 Jul 16, 2010
    When I power up my laptop hp pavilion dv9608 the screen is black. I can barely see anything on the screen. But I can plug an external monitor to my laptop and the external monitor work perfect off of my laptop. I can hear my laptop running and it boots up fine, but again, my monitor display in black. Help???
  • jasongree88 Jul 17, 2010
    Very helpful
  • HP Master
  • 6,993 Answers
the problem is obviously from your laptop's screen bulb or you can all it back light. Its burnt and needs to be replaced.
Once this is replaced, the screen will light up and work normal again.
Good luck.
Posted on Jul 16, 2010
  • 1 more comment
    Okay, can I get this problem fixed at maybe BestBuy in one day, I am actually in another state at this moment and all of my business in on my laptop. I'm stuck at the moment without my laptop!!
    Is it hard to replace the backlit inverter in an hp dv9608?
  • Walesarumi
    Walesarumi Jul 17, 2010
    "Is it hard to replace the backlit inverter in an hp dv9608?"
    I'm sorry for not replying on time. Its not a difficult task to replace the back light of hp dv9608.
    All you need to do is to carefully dismantle the laptop, unscrew all the screen on the screen area. You might not see the screw not until you remove the a the rubber blocking the screws.
    Take care.
  • 4,281 Answers
You can get display on external monitor so your laptop is working fine.
Not you need to check graphic resolution.
For that when you power up the computer press F8 key then you can see safe mode and other menu enter in enable vga mode then go to start ->control panel->display ->settings then change screen resolution to 1024*768 then apply .
But if you are unable to see safe mode and other menu then your lcd display need repairing.
Let me know if you need further assistance.
Thanks for using FixYa.
The backlight for my pavilion dv2000 is not lighting up. the laptop boot ugh i can see faintly, am able to move the mouse and open any program the screen remains so faint ie partially black
Well looks like your cfl tube is dead or the card powering it is dead. the easiest thing to do is to
find a Laptop repair center, the can change either the backlight tube (like a neon tube really) or the inverter or the whole screen.
You might want to try it yourself if you find a working screen for your HP.
Is is fastidious but not that dificult.
Here you can see a step by step tutorial on how to remove the screen for another Hp model.
May 17, 2011 | Computers & Internet
I have the hp pavilion dv7 it powers on but the screen stays black
Try to connect to an external monitor and see if this give an image. If it does, then the Inverter / backlight or possibly the VDU cable on your laptop is damaged.
If it does not, the issue is most likely a failed graphics chip (common on these models). You CAN get the chip "reballed" but this will cost about £70.00, and not guaranteed to last
Dec 29, 2010 | HP Pavilion dv7-1245dx Notebook
What can I do to fix my hp pavilion tx2000 because it shows a black screen when I turn it on but everything else works fine and it even worked perfect when I connected it to another monitor by vga
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 15, 2010 | HP Pavilion TX2000Z Notebook
My screen is dark, appears like no back light, but everything else still works fine. can faintly see screen
Hello
If you can faintly see the screen I would guess the back lights are like you said....not working.
Can you hook up a external monitor or TV so you can still use it and get your files in order. or until you choose to get it fixed. I would get a couple of estimates first
I also found this video if you want to replace the back light inverter yourself.
http://www.youtube.com/watch?v=UT2GFVem_9U&feature=PlayList&p=70B03BCB27E35519&playnext=1&playnext_from=PL&index=16
Feb 23, 2010 | HP Pavilion dv1000 Notebook
Black screen
take a flashlight and look at the LCD screen and see if there is a faint picture to it. if there is, its a bad backlight.
if no picture you can hook an external monitor to it and switch the mon out to the external. usually this requires a FN key + monitor select function key pressed at the same time.
Aug 06, 2009 | UltraLast FOR HP PAVILION ZE 4000/5000...
HP Pavilion Entertainment Laptop Monitor flickers black
If the laptop is under a year old it could still be under warranty and if so I would get it repaired under warranty.
OTHERWISE
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion laptop screen has gone black/blank
You can either use an external monitor for working with the laptop or talk to HP for replacement.
The best option is to use external monitor to backup data before sending it to replacement.
Good luck
Jun 22, 2009 | HP Pavilion dv6835nr Notebook
Screen went black whilst using it
You could have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 13, 2009 | HP Computers & Internet
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion xt1170
- lcd backlight inside the lcd, or the inverter itself. Can you see a very faint image? - Very hard to tel if it's backlight or inverter, or both. Each part costs about $30. Backlight: www.lcdpart.com inverter: ebay Labour is not included, but will cost roughly $75. Still much cheaper to repair than to buy new parts from nanufacturer.
Aug 16, 2007 | HP Pav ZT1170 Monitor
HP Pavilion dv9608ca  PC Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
