Question about LG LRSC-26922 Side by Side Refrigerator
Lg refrigerator water dispenser would not shut off
I took off the rubber gasket to stop the flow from being triggered. Don't know how to reattach the gasket.
  • 5 more comments
  • cairo829 Apr 28, 2008
    Well thanks for trying. I ended up fixing myself by taking off the control panel/faceplate.
    You have to be careful not to snap off the plastic tabs (I broke a couple but it did not affect the remounting of the panel.
    You also have to be careful removing the ice dispenser funnel, it has four plastic tabs that mount that too.
  • Frank G1 Jun 30, 2008
    I have the exact same fridge and have the same problem. I found that if you push hard to the left of the dispenser activator, the flow of water or ice will stop. Seems like there should be a free upgrade/repair to this since looks like a common problem.
    The funnel that directs ice from the dispenser to your container broke off mine. When I called LG for a new part, they said it has been redesigned and they sold me the new aparatus. (Again, must be a common problem if the engineers redesigned the system but they wouldn't offer a free replacement part)
  • privateuse Aug 16, 2008
    How do you take off the control panel?
  • k8lynjuju Oct 07, 2008
    i need to order a new funnel for icemaker
  • Anonymous Feb 04, 2009
    Where are the tabs that break? Bottom, top? I started to pry the trim ring off but was marking it up. Where are the tabs and how do I pry them open?
  • rsting3 Feb 04, 2009
    How do you get the control panel off? Where are the tabs? How do you pry on the tabs since I probably can't see them?
  • cebowens Feb 16, 2009
    I have an LG LRSC26925TT refrigerator, the water and ice maker stop working and I change the water filter.
So two things I have learned. First if the tabs on the funnel break dont buy a new one just crazy glue back in place. Also if you take the gasket out put vaseline on the nubbins and they will slide back in place without having to take the panel apart. Fix time 7 minutes. Booyah!!!
Posted on Feb 02, 2010
  • Alex Chianuri
    Alex Chianuri Dec 01, 2011
    brilliant! it took me a whole 2 mins to drive all the nubbins in using the dull end of a wooden skewer (for fine control and pushing them in). beats removing the control panel!
My funnel also broke from my ice dispensor and they sold me the updated part and funnel frame. How did you replace the frame?
Posted on Jul 26, 2008
  • 489 Answers
You will need to remove the control panel to reinstall the rubber gasket.  Best to call a qualified LG technician for that job.
Posted on Apr 27, 2008
Nail gun no longer fires. Leaks air around trigger when trigger depressed. It is in single fire mode.
You will have to take the gun apart and change the rubber o-ring gasket for the trigger mechanism..Go to a Home Depot or other contractor outlet to get parts or info...The gasket actually keeps the air from leaking so it will nail.
Oct 24, 2013 | Air Tools & Compressors
My 2004 Armada is leaking oil right above the oil filter, at a joint where there's a pressed steel piece. No, I'm not using the wrong filter, and, no, I don't have two (or "no")...
I had the same problem. I took my vehicle to the mechanic. My armada doesn't leak any more. Change the oil filter housing gasket. It cost me $10 for gasket and $45 for labor.
Sep 08, 2011 | 2006 Nissan Armada
When using n60 nailer, one nail goes all the way in, but the next nail only goes halfway in and the some don't go in at all. Don't know what's wrong.
Worn orings in gun and the trigger valve can/will cause problems as you describe. Remove the nails and leave open the latch. Lighty tap the nose of the gun against coiled rubber hose. The driver/piston should stay in the top position (if the driver is down or comes down after test, replace driver oring). Now push the nose against the rubber hose and activate/hold trigger, while holding the trigger/gun in this position, the driver will /should stay down under pressure. At this point no air should leak out of the nose of the gun. If air leaks out of the nose, examine the lower bumper for cracks ( replace as needed ). Finally remove the trigger and examine the firing valve pin. If it has a plastic pin, looks worn and wobbles from side to side, most likely needs to be replaced. If however it has a metal pin and it seems to fit snugly, do not change unless it is leaking air. Good luck
Jun 19, 2011 | Stanley Bostitch Air Nailer Trigger N60...
Furnace not starting
That small tube is the vent verification hose. Air passing over an oriface creates a vacuum. This negative reading, usually about -0.4 inches of water column is enough to trigger a vaccum diaphram switch telling the unit there is enough air flow through the unit to support combustion and remove byproducts safely
Sep 12, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Dyson DC07 Clear Bin Flap will not release
I just received my replacement root cyclone in the mail today after waiting in the back-ordered status for three months. I positioned a butter knife in between the rubber gasket on the bottom flap lid and the bottom rim of the clear bin at the farthest point from the hinge and slowly and gently wiggled the knife between until the bottom flap just fell open. I examined the rubber gasket and it survived without injury and the bottom flap seals without any gaps...good luck
Jun 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Took tank off and reinstalled 9 times - put new gaskets and rings in - but it leaks. Tank also wiggles a bit.
Go to the hardware store and get a tube of plumber's grease. Then grease up the gaskets and the rubber ring. Snug everything down and if it leaks snug it down a bit more
Apr 26, 2009 | Home
Pontiac grand am leaks water into front floorboard when it rains
I had the same problem on my 97 G AM for about a year now, Water getting on the driver side carpet all the way to the back,it just got worst over time, But I found the problem, you have to look behind the wiper motor where the fire wall meets the bodi ,there is a hire line crack rigth behind the wiper motor where the water coming from the wiper cowling drains from ther is some kind of coulking that is painted the same color as the car, you must clean the area with a screwdriver and soap, and use clear silicon with a coulking gun, you must remove the 2 top wiper motor screws do not remove the botom one not need to and remove the 2 wire plugs and pull the motor back and rotaded upwards know youre clear to do the job; good luck it worked for me.
Mar 23, 2009 | 1995 Pontiac Grand Am
Duet washer rubber gasket replacement
ive never taken the front panel off, ill give you its tigth anbd dark, but the clamp inside is removed with a small ratchet( 9/32" is size), its definetly a little aawkward, to undo, adn even more to reattach, butit can be done with A LOT of patience
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG LRSC-26922 Side by Side Refrigerator Logo
3,367 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
