Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Ice machine flooding back not making ice - Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
    Guru:
  • 1,524 Answers
Bad float switch.
Posted on Jul 21, 2010
Hi .my hoshizaki ice machine it till running but do not make ice . Can you tell me , what wrong with the machine ? Thank you
The machine, all in one, not indoor/outdoor split type, will make beeping sound when something is wrong and stops working until it is turned off and turned back on. Some times the machine needs to be reset with the power on, covers removed, reset button inside on electronic mother board.
The ice machine covers have instructions and information on beeping sounds.
Aug 27, 2017 | Hoshizaki Freezers
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Do you have to reset ice machine after running wash cycle? Mine is not making ice now?
If you did the wash cycle per the manufacturer instructions, you may have forgotten to turn the directional water valve back. It directs the water/cleaning solution to go inbetween the plates. It has a micro switch that will not let the compressor come on. If you did turn it back, the switch may be bad.
Check it out.
Mar 03, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Only makes one round of ice !!!! Does not despence.
the overloding or relay is not good , or you have insufficient power supply
Jan 24, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Beeps 3 times when turned on
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
Jun 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Icemaker makes 2 dumps of ice & then shuts down.
Look on the inside of the front panel. Should be a chart to tell you what the beeps mean. Hoshi has a great tech support line in Peachtree City. It's worth the wait to talk to them.
Jan 26, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My Servis fridge/freezer sounds like Darth Vader
We had the same problem and discovered that the ice making device was "on" and we don't have it hooked up.  In the "on" position the pump begins to run but there is no water to pull so it sounds like breathing.  The ice making bar for us on our Jenn-Air is located near the ice trays and ours needs to be in the up position for off.  Hope this helps!
Jan 11, 2009 | Frost Freezer WCWO F15WA FREE - POCKET...
Ice maker runs continueously
I don't have the details on you machine but if I were going to trouble shoot this problem, assuming its a temperature probe I would power off the machine, remove the access panel and remove the temperature probe and check it with an Ohm meter or continuity checker for proper functioning by putting the probe in ice and see if it opens electrically. Sometimes the probe is not a simple thermostat type. The bin control on some machines is optical. The ice pile breaks a light beam to turn off ice making. Sometimes the probe is a thermistor. These latter two kinds of probes have electronics connected to them. A simple ohm check will not work for these cases. You can tell what kind you have by looking at it carefully. The thermostat kind that can be checked with a continuity checker or ohm meter is a sealed metal tube. The optical type has a light source and a separate pick up sensor. The thermistor type is a very small device on the end of a pair of wires. For the optical type or the thermistor type write back for more details.
Nov 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
245 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
