Question about RCA L46WD22 Television
AS DESCRIBE UNUSABLE SIGNAL NO MATTER WHAT YOU DO
  • RCA Master
  • 11,800 Answers
I suppose you are referring to the antenna/cable signal and you have tried the antenna entry by plugging another local source (as a player) with the same result. In that case the tuner is dead. It can't be fixed so it must be replaced. Luckily it can be removed from the mainboard so it will be a cheap and easy fix.
Posted on Jul 16, 2010
  • Saul Mayorga
    Saul Mayorga Jul 21, 2010
    OK THIS PROBLEM IS NOT THE TUNER I'M A TECHNICIAN AND THE TUNER IS NOT THE PROB LEM THERE IS A MOUNT SURFACE FUSE THAT GOES OUT ON THIS UNITS FOR NO APARENT REAZON THERE IS SOMEONE THAT POSTED THE LOCATION OF THIS FUSE AND I WANT TO KNOW IF YOU CAN ASSIST ME BY GIVING ME THE LOCATION OR THE WEBSITE WHERE IT WAS POSTED
  • Azrael SRL Jul 21, 2010
     Fuse 1C33 , on ADM board, location top left hand corner, on the part you will see the word "F" on top of the part, fuse is wrong size 500mA new part # 275819 750mA just add it on top of the old one.
    And stop using caps, it's not nice to SHOUT.
My rca tv has unusable signal onit
Hi, Check the cable connections to and from the TV.
Change the channels to see if there are others that are out.
If you are not using any cable company then you will still need a set top box to unscramble the digital signal. Good luck.
Jun 06, 2012 | Televison & Video
Entivoe DVD player worked fine. The next day, the tray opens, closes and the power turns on and off but the screen says only "Unusable signal", either with or without a video disc in the player. If there...
check the connection cable to the tv, unplug this an replug it to see if this helps.
if you used a cheaper HDMI cable for example the connectors are very wobbly and often make poor contact....
Aug 31, 2010 | Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Model L42WD22 unusable signal
did you ever find a solution for this... I am experiencing an issue with 'unusable signal' and have my cable through Rogers
Oct 16, 2009 | RCA Televison & Video
RCA TV
my tv shows a black screen with words saying...UNUSABLE SIGNAL
Sep 07, 2008 | Televison & Video
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
Unusable signal
A brand and model would be helpful. However if you have some knowledge on TV's you could try replacing the Jungle IC first. This usually controls the AV inputs on a standard CRT. Probable cause, Static on the Video line. Good Luck. Jus004
Dec 07, 2007 | Televison & Video
RCA L46WD22 Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
