Question about Microsoft Windows XP Media Center Edition 2005 for PC
My computer needs a code for the volume what should i do??
    President:
  • 2,340 Answers
Buy the licence.
Posted on Jul 18, 2010
Just purchased Samson dynamic microphone. Can we use this with a portable stereo or computer? If yes, how does it work? What do we do to set it up?
You can use it with a portable stereo that has a microphone input socket - just plug it in. You may need to adjust a mic volume control - this will vary from one system to another.
With a computer just plug it onto the microphone input socket (usually colour coded red or pink)
You will also need to enable it in 'control panel' - see below.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 14, 2011 | Samson Dynamic Vocal Microphone
Hey I lost the remote to the midiland mli 750 and I can't increase or decease the volume and the last volume I left it at was 25 and I can't even hear anything now is there a way to increase the volume...
you can try programable remnotes using the hometheater code entries , but more than likely you will need to buy a factory replacement remote.
http://www.remotecontrolscenter.com/
Nov 29, 2010 | MidiLand MLi 750 Computer Speakers
Need to calibrate my projector but i need services codes
try volume up-down, video,effect, computer, or volume down-up and different combinations of video,effect and computer. It's been along time since I serviced one of these but trial and error should give you the factory menu.
Oct 19, 2010 | InFocus ASK Proxima M2+ Multimedia...
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
How do yu unlock an ipod volume that yu may have put a code to.. or yu may have not put a code to
On your iPod go to Settings, then Music, then Volume Limit. You can change the volume limit there. If you have locked it and cannot remember the passcode, you will need to do a hard reset, which will result in you loosing your data, but you will be able to restore it with your synced computer.
Hope this helps,
Thomas
Apr 07, 2010 | Apple iPod touch
I have some multi speakers but the volume not coming out
You don't give me much to go on so here is everything that I can think of:
Remember that there are two volume settings. The volume knob on the speakers and the volume in the computer. Make sure the speaker and computer volume is up and Mute is off.
Make sure the speakers have power. Most of them have a light to show that they are on.
Make sure the speakers are plugged into the the right port on the computer. The audio out port is usually color-coded green.
You can plug a pair of headphones into the computers audio port to see if they work. This will tell you if the problem is with the computer or the speakers. (Don't put the headphones on for this test, the sound might be very loud.)
The last thing would be if a sound driver is not installed on your computer. If you have a sound driver there is usually a small speaker icon next to your clock. No speaker icon and you may need a driver. You can download a sound/audio driver from your computer manufacturer's website.
I hope this helps.
Jan 29, 2010 | Computers & Internet
Volume limit unlock code
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the device
(or restore from a backup). If you restore on a different computer that was never synced with the
device, you will be able to unlock the device for use and remove the passcode, but your data will not
be present Follow the steps that i have outlined below. If this does not completely help your situation please
let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Apr 17, 2009 | Apple iPod MA446LL/A MP3 Player
Adjusting Volume on my Ipod Nano
If it is the unlock code plug your ipod into itunes then goto to settings for the device and click change password
Oct 27, 2007 | Audio Players & Recorders
Microsoft Windows XP Media Center Edition 2005 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
