Question about Quasar HQ2051TH Air Conditioner
Not cool im using, then i slept didnt notice the rain, from now on didnt cold much
  • 57 Answers
Check the reset button on the plug cord. if ok, check your fuse box.
Posted on Jul 16, 2010
Fixya car
there might be a thermostat problem, is the engine temperature too low (cold), thermostat regulates the water flowing to the engine, when engine becomes hot (it opens) and allows the water to circulate thus cools the engine and when cold (it closes) cutting circulation to increase temperature on engine up to normal operating temperature, "may be it still remains open even the engine is cool. "cold engine loose power and sometimes jerks or misfire sometimes it totally shuts down and hard to start.
Jun 04, 2013 | Motorcycles
I have dometic AC 630515.331. I was having a problem with it cooling properly. A service guy checked it out and said the cold control wasnt working properly. Im trying to replace it but I dont see a cold...
When you say, wasn't cooling properly, could you give more details such as, cooling would not shut off, cooling would cut out before trailer was cool, fins/coils were frosting or freezing up. Compressor was kicking out and in too much or any other symptom you notice. All will help with proper diagnosis.
Apr 02, 2013 | Dometic Rooftop RV Air Conditioner
I keep getting the code p1729
code 1729 is EMC SHORT TO GROUND. YOUR EMC TCCU CONNECTOR LOSSE OR POOR TERMINAL TO WIRE CONNECTOR.POSSIBLE RAIN WATER CAUSING SHORTING PROBLEMS,WATER AND ELECTRICITY DONT MIX.
Oct 01, 2012 | Cars & Trucks
Water seesm to leak from behind fan housing when it rain and after air conditoner is turned off
water dripping from a.c after being used is normal on any vehicle, its just condensation frome warm air and cold ac lines, as for rain its probably just rain water coming through the front end, however if the water is reddish or green in color it would indicate a coolant leak and would be noticable much more often.
Jun 09, 2012 | 2002 Audi A4
Belt comes off when it rains
THEN CHECK THE DRIVE BELTS THAT IS WHERE THE BELT RUN (DISKS) OR BUY THE BELT BUT A OEM ONE NOT THE REPLEMENT OR GENERIC.
Jan 10, 2012 | 1998 Dodge Grand Caravan
Dont seem to get cold air, what is the best symbol to use? There is sun, snowflake, rain drop and few others either way it takes forever to get the house cold and sometimes it just simply just does not...
To get cold air set temp 23 degree and mode "cool".
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Dec 30, 2010 | Heating & Cooling
Heating stays on and no a/c
this is probably in the knob that you adjust the hot/cold, some of these knobs actually run a cable and spring time is the first time its noticed because during the winter if you tried to adjust the knob you adusted it to heat and then tried for cool for fresh air or something, the hinges on doors in the duct work were stiff or grease was solid and put too much on the gear system or cam system that runs the cables and it broke. but you didnt' notice it until spring/summer because you didn't fully need the 'cool' air until then. however if yours is an electric switch then you probably have a bad contact. it is also possible that a vacuum line could be broke, ford used vacuum to move duct doors through the 2000's
Jun 15, 2010 | 1999 Ford Windstar
Audi A6 Hesitates to start
Check your fuel injector fuel regulator. more likely the injector are leaking .
Aug 03, 2009 | 2003 Audi A6
Refrigerator and freezer not cooling
you may need to refill the freeon gas charge
May 30, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Hey spike
Ekse
All cool. apology accepted
Apr 09, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Quasar HQ2051TH Air Conditioner Logo
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
