Question about Panasonic DMR-EH57 HDD Recorder Player
Panasonic DMR-XW380 often picture distorts and
Panasonic DMR-XW380 often picture distorts and stops and starts during playback making viewing impossible. Viewing on onnolog set via
set top box. viewing same channels live all ok
  • adaish33 Jul 16, 2010
    thankyou for your help. I shall have unit checked
    Alan Daish
  • Panasonic Master
  • 11,800 Answers
I suppose you have tried to view the panasonic with it connected directly to the tv and you got the same result.
When you record the image is converted to avi then stored on the internal hard disk. When you play that recording the data is read from the hard disk then converted back to analog. If you have errors during playback those can appear in only 2 places: either the hard disk is dying and must be replaced or the processor responsible of the coding and decoding is malfunctioning. If you're lucky the processor might be just overheating so a simple cleaning will be enough (add a small fan to prevent this from happening again). If you're unlucky the processor has suffered a severe damage and must be replaced. Since it's glued to the mainboard it must be replaced as a whole, making this a very expensive failure. Time to save for a new one, it will be cheaper than to fix this one.
Posted on Jul 16, 2010
Increase size of hard drive
It might be able to be done but the best way it to get a external usb hard drive. If your system will let you. I don't think you can put another HD in it because the software that makes your system run is on the orig. one no way to transfer from one to another with out a high price HD copier.
Feb 19, 2015 | Panasonic Dmr-XW380 Dvd Recorder
How do I fix my Panasonic DVD Recorder DMR-XW380
U99 Hi. This indicates a communication error between the timer and main processor unit. Try unplugging from the wall for a minute or two, and plugging it in again, to reset everything.
Sep 12, 2014 | Televison & Video
How do I change the DVD1 code on the unit ? Old recorder need to be set on 4 to work
Ring the manufacturer and ask for the code. Ring during business hours. They may not want to give it to you because it voids warranty. But be persistant and theyll give it to you. Write the instructions down carefully - they can be a sequence of codes/steps.
Mar 01, 2014 | Panasonic Dmr-XW380 Dvd Recorder
Stop button on my remote has stopped working, so using the pause button now then have to push again to play. Does this mean the remote is stuffed?
Probably. You could try spraying some switch cleaner (from electronics stores) into the gap between Stop button and body of the remote, but if that fails, try eBay or similar sites for a replacement
Aug 05, 2013 | Panasonic Dmr-XW380 Dvd Recorder
TV screen goes blank, still have sound. Is it our freeview box or the TV.
There are some firmware updates available for the DMR-XW380 that you might want to consider at least looking at.
http://panasonic.jp/support/global/cs/dvd/download/xw480/index.html
May 16, 2012 | Panasonic Viera TC-37LZ85 LCD TV
Pixelated picture on all channels when viewing tv through xw380 recorder
If you are in a good reception area and your tv channels are coming fine it does look like a recorder issue, try another HDMI cord just to be safe, now when you tried in the shop was that through a different tv? if that is the case the input signal needs to be checked with another device.
Apr 14, 2012 | Panasonic Dmr-XW380 Dvd Recorder
Require an operation manual for a panasonic dvd recorder dmr-xw380
You can download and print the operation manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Nov 24, 2010 | Panasonic DMREZ27 DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    Distorted picture after stopping a dvd
    How are you devices connected, in what order and with what cables?
    Dec 27, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
    Panasonic DMR-EH57 HDD Recorder Player Logo
    391 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
