I just bought a second hand LG WD8050FH washer I saw it working in the sellers house but when I got it home as soon as I turned it on my circuit breaker shut off and so does the machines power. I have turned off all my other appliances at the switch but the washer still continues to shut down within seconds of turning it on and before any cycle begins.
  • kimvnewman Jul 19, 2010
    I just bought a second hand LG WD8050FH washer I saw it working in the sellers house but when I got it home as soon as I turned it on my circuit breaker shut off and so does the machines power. I have turned off all my other appliances at the switch but the washer still continues to shut down within seconds of turning it on and before any cycle begins.I've tried other sockets and the same problem I presume there is a short somewhere in the machine. How do I go about finding the fault?
  • 3,051 Answers
Hello there:
Alot of times the circuit breaker that operates this machine may be different than the previous owners so check the amperage of the circuit that it is on it may be too weak to run this machine each machine has a certain amperage that it calls for and if yours is not enough than this will be the result tripping breakers ect ect
Also somtimes this circuit may feed more than one thing so in this case i would try to plug it in in a different outlet via a extention cord to test and if it now works than you will know what the problem is ok
Hope this helps
Best regards Michael
Posted on Jul 19, 2010
    President:
  • 1,891 Answers
Try the machine on a different power supply . or try a appliance that you know is ok on this power . if power ck's ok then look for a pinched or shorted wire caused by the move .. good luck hope this helps .. mm
Posted on Jul 16, 2010
  • 5 more comments
  • kimvnewman Jul 16, 2010
    I tried as you suggested using other sockets and it still shorts in 3 or 4 seconds The lead in the back seems to be OK no damage or pinching
    pinching
  • dennis dodge Jul 16, 2010
    SOUNDS LIKE THE PROBLEM IS IN THE DRYER ITSELF. . CK FOR SHORTED ELEMENT
  • kimvnewman Jul 18, 2010
    How do I check for shorted element
    How do I check for a short
    It isn't a dryer its a washing machine
  • dennis dodge Jul 19, 2010
    sorry about the (dryer) but the things i wanted you to ck still apply / w or dryer / if you saw it working before you brought it home then i think it was the trip home . thing happen ..do you know if power is 220 or 110. volts. .. and shorting out will blow fuses .and just quiting in 4 to 10 sec could be a open connecton in the wiring . so if not shorting but just quiting .. i would look for loose conection in any or all components . like the harness to the motor . / timer / or any swithces. / disconect them and re plug the in making sure connections are tight . .. your problem ins't a easy one because . unit quit working when the location changed . . so we are look ing at something that the move caused . or the new hook up created .. so lets keep on trying . .. mm
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
I bought a vtech v flash used....no adapter or cable came with it, i would like to know what to purchase
Make sure it's not second hand. Sometimes if second hand then the seller might have did something to the wire so just sold the vtech v flash.
Dec 27, 2010 | Vtech V.Flash Home Edutainment Learning...
My Delta radial saw motor keeps tripping the GFCI circuit. I've tried several separate circuits and they all trip as soon as I turn on the motor (even a 20 amp dedicated circuit). I took off the motor...
saws draw a lot of amps at start up and will normally blow any GFi circuit, if it does the same in a normal outlet,, you might have to disassemble your saw for a good cleaning and lube,,
Aug 03, 2010 | Ryobi Circular Saw W/Dual Laser
Bought a LG LD 05AW2 benchtop dishwasher second
More than likely it is the electronic control board.
Feb 26, 2010 | LG Dishwashers
Does not turn on. The wood was at an angle and jammed when it quit working
Hello. I recommend that you check your circuit breaker or fuse which is in the house panel and feeds the outlet that your saw is plugged into.
I believe that you will find that you solution is to reset the breaker or change the fuse.
Nov 28, 2009 | Craftsman 10" Table Saw
Zoom error on my daughters fujifilm a700
Try calling Fuji support and seeing if you can get it repaired or replaced. The camera as it is, is defective.
Dec 29, 2008 | Fuji FinePix A700 Digital Camera
LG front load washer spinsense buttom does not come on
I have the LG WM3988HWA, which is a washer and dryer in one. The way it works on ours is that you press and hold the Spinsense button for 3 seconds before you start a wash, or while a wash is paused. When Spinsense is on, the LCD will say "Spinsense" on the right-hand side when the machine is running. Nothing happens with the light on the Spinsense button.
Spinsense makes a huge difference as the machine is on the second floor of our old wooden house. I don't even notice the spin cycle with Spinsense on.
Problems:
1. We need to turn it on for every load. This is just annoying.
2. Spinsense will not turn on when you've the Dryer option activated. This means we have to do two trips to the machine for each load, or have our house feel like it's shaking to pieces. There's no good reason that the Spinsense/Dryer shouldn't work.
Jun 24, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
