Question about Taylor 70144012 Ultra Slim Lithium Electronic Digital Scale ()
Either reads to much weight or not enough - Taylor 70144012 Ultra Slim Lithium Electronic Digital Scale ()
  • 10,865 Answers
Hi. Time to change the batteries. J.
Posted on Jul 16, 2010
My conair model th300 is giving me a reading of 288.8 then it goes to err.
I was thinking there were too reasons for this, but I can't find the specs on this scale. One reason may be that its upper weight has been exceeded, but I think that is unlikely. My other thought is that the battery is failing. It is enough to make it come one, and to register your weight, but not enough to continually display it. The instructions indicate it has a 3 volt lithium battery in a compartment in the back.
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=0ahUKEwjintjyt97RAhVU1mMKHdGnCQQQFghCMAY&url=http%3A%2F%2Fwww.conairscales.com%2Fcatalog.php%3Fproduct_id%3D428%26ib%3Den&usg=AFQjCNEp2iyMiCxDasXeoxeI_3r1no7RTA
Jan 25, 2017 | Conair Health & Beauty
What is a good strategy for playing table shuffleboard in regards to weight placement?
To earn the most points you will need to slide your weights as far down the table as possible, coming as close to the edge as possible without falling off. You should then guard your highest scoring weights by blocking them with other weights. Do this by shooting them close enough to act as a barricade, yet far enough that in case you opponent knocks one, they will not both fall off the edge.
Aug 20, 2012 | Sport & Outdoor - Others
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Nothing will display on the read out
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
Grohe faucet handle doesn't retract
Ok well that is probably the install then.  there is a brass ring under the sink that is holding the faucet tight to the sink.  this has 2 water lines that feed the faucet and the line to your spout.  if the copper lines are not pushed apart enough than it will rub one the line with the weight and make it hard to move up and down. you need to get under it with a flash light and move these lines apart.  The worst  would be that when the faucet was installed the hole was not big enough and that is what it is hitting.  So I hope this help you .
Jun 23, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Weight Limt
thats a great question and i am wondering the same thing i weight in at about 240 and it seems to ride fine beside the noises it make but im thinkin the noise is because it is brand new... i have heard nothing about weight limits and read the entire manual and read nothing about weight limits so im assuming there is no limit .....
Jul 12, 2008 | Electrical Supplies
Taylor 70144012 Ultra Slim Lithium Electronic Digital Scale () Logo
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
