My computer always restart and display "please check signal cable"
  • 10,865 Answers
Hi. turn it off, unplug the cables and clean the ends with some electronic contact spray available at any auto parts store. J.
Posted on Jul 16, 2010
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
I have bought a mew computer with a Sansung screem type LS19A300. It was working normaly and then a message "check signal cable" appeared. I checked all cables and nothing. So we changed the new...
Hi, what was the LCD displaying is that he is not sensing any signal from the computer video port that is why it is prompting "check signal cable". Have you tried checking the pins of your video cable from your LCD? if OK please plug in the cable again when your PC is already open to check that signal will pass thru and lets see what happen. If still the same, try to isolate it with laptop as external video if you have to check the LCD will work with other PC. If the same, replace the signal cable of your LCD if it is removable to further check the problem.
Jun 23, 2011 | Samsung SyncMaster 910T 19" LCD Monitor
Cannot get my iomege z100PS to work....green and amber lights stay on with AC and computer cable connected or just with AC cable connected.
A signal display on the devices is indication of normal functionality. Attempt to restart the device, also restart the computer to attain reconfiguration settings.
Feb 06, 2011 | Iomega Z100P2 External ZIP Drive
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
No screen signal
1.Check your hard drive.
that's where the information for Windows resides.
2. check your video card / removing it and replacing it with a know good video graphic card will let you isolate the issue more.
3. check the cable ( vga) to the
4. monitor >>>go to another computer and connect video cable to the computer. if you get a display then you know the monitor is OK.
5. Isolate each component of each path.
Apr 27, 2010 | Gateway GT5674 Desktop PC
CHEK YOUR pc OR SIGNAL CABALE
You should Check monitor on different system, after that, although if your monitor is ok then you should check your display your System (CPU) restart the syatem and check display in Key-board by pressing Num Lock Key whether on or off, if key is not working so problem in your system not in Monitor, check then reply
I hope that this has been very helpful for you
Dec 01, 2009 | AOpen A75P Monitor
THE HAVE LIGHT,NO DISPLAY YELLOW LED
This is generally caused by no video signal from the computer. Try the monitor with another known working computer. If it works there, the video card (or onboard video) of the original computer is faulty. Otherwise, it is a problem with the incoming signal circuitry of the monitor (or cable).
May 26, 2009 | Acer Computers & Internet
My screen won't turn on when i start up computer. i have pluged the original grafics card in and pluged the rgb wire in but theres just no signal comein from pc??? any sujestions on how to instal it or...
sometimes the fault is not always from the graphic card ... it could come from the processor or the memory .... please check them too and also check the signal cable especially the pins on the signal plug
May 18, 2009 | Computers & Internet
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Jan 25, 2009 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
