Question about GE GSS25JFM Side by Side Refrigerator
Starts heating after 3-4 days - GE GSS25JFM Side by Side Refrigerator
    Scholar:
  • 186 Answers
Sounds like it is defrosting the defrost will come on every so many hours depending on how it is set
Posted on Jul 16, 2010
How to fix my saab heated driver seat that gets too hot
As the heater elements get older the parts of them can break down, when this happens the overall resistance reduces so more current passes through the existing elements, causing those left to get hotter.
If left they will burn out completely, there is also a possibility they could damage the upholstery or even catch fire.
Sep 29, 2014 | 2006 Saab 9-3
I have a ~4year old Dometic RV refrigerator that does not start cooling when started after periods of being shut off (as little as 2-3 days). When I turn it on I can hear the fan start but after 2-3 hours...
ammonia absorption refrigerators need continuous heat either by
a heating coil powered by a transformer or, a propane flame
check/replace your gas thermocouple or, transformer to the heating coil located on the refrigerator back
Aug 21, 2013 | Refrigerators
I have 95 gmc jimmy 4x4 it is still over heating after i changed theromstat
Damaged impeller on the water pump, or a leaking head gasket ?
Is the fan clutch working correctly ?
Aug 29, 2012 | 1998 GMC Jimmy
Good day! A condo suite has a programable digital thermostat operating on 24v for heat (geothermal heat pump solenoid valve) ac, and a humidifier to control. When the humidifier kicks the fan coil...
Hi, start at the thermostat on this unit if nothing else has been done as far as trouble shooting and repairs. 3 months doesn't mean a thing when it comes to a/c and refrigeration & heating parts. Check the stat operation, or replace it, and I am 99.9% sure this will solve your control problems.
Sincerely, and a good day to you!
Shastalaker7
A/C, Heating & Refrigeration Contractor.
Feb 09, 2011 | Heating & Cooling
From time to time stops working and making a noise like boling water
A refrigerator must defrost 2 - 3 times a day. It does this via the automatic defrost cycle. When the cycle starts alll motors shut off and there is a heating element that is in the evaporator / freezer section of your unit. That heating element melts the ice until the 60 Deg F bi-metal thermostat cycles and terminated the automatic defrost cycle. During the defrost cycle is is normal to hear a hissing sound as the melting ice drips on the heating element assy. Addiionally you may hear coolant gurgles as the unit shuts off to start the defrost cycle and the coolant system equalizes the internal pressures between the pressure and return lines. Again another normal sound. If your unit did not stop to defrost 2 - 3 times a day in a matter of 3 to 4 days you would have a large block of ice in the back of your freezer section and the evaporator fan blades would be hitting that ice block. The freezer would say cool yet probably no longer make ice. Also the fresh food compartment would start warming up. Hopefully this resolves your concerns. If you need more assistance just respond to this post and I will help you.
Thanks for choosing FixYa.
Kelly
Sep 05, 2010 | AEG S72348KA ST STEEL Refrigerator
Fujitsu 18000 goes into defrost once an hour at 28to 32 degrees outside temp. trying to maintain 70 degrees inside . test run was ok on start up. just installed 3 days ago .. vacuum out the lines. lost...
what is the lowest outside temp manufacturer suggests? Heat pumps are not very good when it gets good and cold... call the installers and see what they have to say for you.
Feb 21, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
Heating element
Give me the complete model # from the sticker on the range so I can assist you.
Oct 17, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE GSS25JFM Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
