Question about Hitachi SB10Y 4 X 8 Inch Belt Disc Sander With Dust Collection
Hi The drive belt on my gmc 4 x 36inch Belt /sander has broken. The old belt has the following information on it:- Unitta 142XL 037. Could you please help to find a replacement belt.
efs_perpends
  • 1996 Answers
SOURCE: BROKEN RUBBER BELT FOR BELT SANDER
Maybe you can use a linked belt to replace it. Check the width of the old drive belt, and give these folks a call: Lee Valley
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Posted on Oct 08, 2008
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 384 Answers
SOURCE: The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Posted on Jun 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: belt sander keeps breaking the belt
by belt do you mean the sanding belt and if so are the belts you are using directional?? If they are there is an arrow inside them to indicate direction of rotation. Also check the wear plate for sharp edges that can cut the belt. Let me know if you need more help
Posted on Aug 26, 2009
Bosh B7350 Belt Sander not working
Did you pull the plastic cover on the left side to see if the drive belt has broken? I think the cover is held on with only one screw.
Jul 15, 2012 | Tools & Hardware - Others
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
I want to replace a broken drive belt for the Br300 Type 1 but am having problems. Please advise as to proceedure for replacing this belt. Thanks in advance for your help.
Look between the rollers that the sandpaper belt travel on. You will find a lever which can be released. Once you release it, you can pull the old belt off and slip the new belt on. Place the release lever back the way it was and you are done.
Apr 15, 2011 | Black & Decker BR300 3''x18'' Belt Sander
Broken drive belt on ryobi band saw, need
Just go to a well equipped hardware or auto parts store. Take the old belt with you so they can find an exact replacement. Good luck!
Apr 26, 2010 | Ryobi 9 in. Benchtop Band Saw
How do you replace the drive belt on a ryobi type be321
I tried the model number and can't find it on their site, but if this is a belt sander or planer you can "roll" the new belt in place without loosening anything. If this is another tool let me know and please give me all the information (tool type) and I will check further.
Aug 23, 2009 | Ryobi Tools & Hardware - Others
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Nov 14, 2008 | Tools & Hardware - Others
Hitachi SB10Y 4 X 8 Inch Belt Disc Sander With Dust Collection Logo
227 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
