Question about GE (PSS26MSRSS) Side by Side Refrigerator
My fridge and freezer get too cold, even though I keep setting it
My fridge and freezer get too cold and though I keep adjusting it higher, the fridge goes to freezing at about 32, and the freezer gets too cold also. I have replaced the temperature display/adjustment panel from across the top of the fridge, but it did not help.
The icemaker also makes too much ice, but that may be a different problem, and minor compared to the temperature problem.
    Scholar:
  • 186 Answers
Try adjusting it lower
Posted on Jul 16, 2010
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile GSS25LGMB
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Temperature too cold even when on lowest
Jul 12, 2009 | Refrigerators
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
377 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
