Coby MP-610  MP3 Player Logo
Posted on Jul 16, 2010
How do u delete the songs - Coby MP-610 MP3 Player
How do i wipe some of the music from the music section on my nokio lumia .
Your phone uses Windows phone 8.1.
For this system there are simple instructions excerpted here and on line here: http://support.xbox.com/en-US/legacy-devices/windows-phone-8/manage-xbox-music-collection
Remove music from your collection
To delete a single song
  1. In the Songs pane, find the song you want to delete.
  2. Tap and hold the song, and then tap Delete.
To delete more than one song
  1. Tap Select (the icon with three lines).
  2. Select the songs to delete. You can also tap More (the ellipses icon) and then Select all to select all the songs, and then unselect the songs you want to keep.
  3. Tap Delete (the trash can icon).
  4. When you see the prompt "This will delete from your phone and cloud connection. Are you sure you want to delete?" tap Ok.
Sep 11, 2017 • Cell Phones
2answers
How do I delete songs from my ipod?
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
Deleting songs
In order to delete songs you either:
In iTunes:
Remove the song by clicking on the line in your library and pressing the delete (del) key and answering yes to delete.
or
Uncheck the song, and under iPod settings click to only sync checked songs. Either way when you resync the song should not be there.
2helpful
2answers
How do you delete songs from Ipod?
To delete music connect ipod to itunes on computer.In music folder under your ipod name you can then delete music.
I hv sansa clip 1gb - in which i have some songs i.e aprox.850mb and that cannot be seen in my pc in sansa clip as a drive g.how to delete songs and add songs , is there any driver of software or...
1. First, check your device setting up on MTP or MSC? Turn on device, go to "settings" , press down or up to find "USB Mode", you can see the check mark at MTP (auto detect) or MSC mode. Change to another usb mode.
2. You have 2 ways to delete songs:
2.1. Delete songs by device: play songs, press down (sub menu) until you meet "delete song", select it and yes
If you delete all items in device: Settings, Format, and yes
2.2. Delete songs by computer: plug device to computer, double click on device icon, Music folder, and delete songs you want. If you don't see songs in there, unplug the device from pc, and then change USB mode, and plug device to pc to delete.
Good luck
3answers
Deleting songs , how do you delete songs off the ipod touch?
connect it to itunes.. click on the ipod and under the music tab.. uncheck sync all music from music library
Deleting songs
Deleting Songs Using Windows Media Player
Use Windows Media Player to view the songs that are stored on your mp3 player - best to view them in the "Sync" tab. Find the song that you want to delete, right-click the song, and select Delete (or left-click and press Delete on your keyboard). Voila!
-Tha Mp3 Doctor
1helpful
2answers
How do I delete songs from my trutech mp3
There are some songs that I don't want and I wish to delete them. But I don't know how to do that. I tried to delete songs on my media player but that won't work. is there some solution to this? Please walk me through this in the most easy way possible if you can.
3answers
Waht to delete some songs from ipod
delete them within I tunes programme
Deleting songs
If your computer says you don't have any, but your MP3 does you can delete it from your MP3 player. Click on the song that you want to delete and go down to delete song. Click on it and whala! the song is deleted
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
