Receiver will not stay on when turned on
When I turn on my Onkyo AV receiver HT R 8230 it will not stay on. It turns right off
  • 616 Answers
Shorted outputs
Posted on Jul 19, 2010
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
My onkyo ht-r590 goes on then shuts off right away.
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Oct 01, 2014 | Onkyo HT-R590 7.1-Channel 3-D Ready Home...
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
I have an Onkyo AV Receiver HT-R500 and when I turn it on, it turns on and in less than one second it turns back to standby. What could be wrong?.
Try disconnecting all the speakers and see if it does the same thing. If it doesn't, connect speakers again one at a time to find out which one of them is doing it. Make sure the speakers rating match the output of the amp.
Jun 16, 2011 | Onkyo HTR500 Receiver
I CAN'T GET MY ONKYO HT-R340 AV RECEIVER TO TURN ON, IT WAS WORKING FINE , STANDBY LIGHT IS ON BUT DOES NOT TURN ON. ANY SUGGESTIONS?
I have the same problem during years, I have the same av rereiver and the device switchOff (even in standby). The red led is not visible. During several hours, rare time minutes it is blocked.
I sent it, the last year to the official technical service and they said me that nothing matter with it!!!
The worst buy made by me, goodluck, if you have solution I will be pleasure of your information
Juan Luis Santiago
Sep 09, 2010 | Onkyo HTR500 Receiver
I have a n onkyo av reciever ht-r560 only the front 3 speakers go on when im using it i know the rest work and are plugged in correctly because the volume tester outputs sound through it. Is there an on...
Your sound might not be working because the HDMI and optical audio inputs might not be working.
I made the mistake of buying the Onkyo HT-560 and in less than two years all of the HDMI video inputs started intermittently breaking. Sometimes when you selected the channel both the image and the sound would not come though.
Also the rear speakers stopped working from time to time and I have to run the setup again to get them to turn back on.
I am not sure that Onkyo was ready to introduce this technology, it has been a nightmare and my stereo is going to cost almost as much as I bought it for to fix it.
Oh and there customer service was no help, they just told to bring it to an "authorized service center for repair". They had also had no idea where there was one in my city it took them a day to get back to me.
The Onkyo HT-S5100 looks almost identical to the HT-560 not sure if they are different in anyway.
Stay away from Onkyo in the future! I know I will.
Sep 02, 2010 | Onkyo HTR500 Receiver
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
Have ajustments all screwed up
If you can’t resolve the issue yourself, try resetting
the AV receiver before contacting your Onkyo dealer.
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. “Clear”
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
Feb 10, 2010 | Onkyo HT-S9100THX 7.1 Channel Receiver and...
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
CORRECT SETUP CODE FOR RECEIVER
that is because i think that your reciever would have its own code
Jan 29, 2007 | Onkyo HT-S790S System
147 people viewed this question
 Grubhead
Grubhead
