Question about Magellan RoadMate 2000 GPS Receiver
Magellan Roadmate 2000.. No GPS signals
The signal icon has no bar, when I double-clicked it there show no satellites were found.
First time use Magellan product, not sure what is wrong with it. Please help...!
    President:
  • 1,111 Answers
Make sure the battery is charged up good, then take it outside and turn it on and leave it in clear view of the open sky for up to 30 minutes to acquire the satellites especially if its been reset.
if that fails, reset the unit...turn it on, then locate the reset button on the left side bottom of the gps and use a paper clip to depress the reset switch...it should restart on its own..take it back outside and let it in clear view of the open sky for up to 30 minutes.
if that fails..go HERE and get the update and follow the instructions..you will have to sign on to the Magellan site before you can download anything.
if you need more help, just post back
bill
Posted on Jul 18, 2010
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
My Magellan Roadmate 3045 is not getting any signal. I turn it on, and it doesn't even attempt to acquire a signal. The satellite icon in the top right-hand corner of the menu which indicates signal...
Mine actually stopped working the same day you posted this. How strange is that? I have not been able to figure out what is wrong with it. Have you figured out a solution?
Aug 06, 2011 | Magellan Roadmate 3045 - uses Gomadic...
The gps is a magellan RoadMate 2000. It does not get a satellite signal and it has been reset and left outside to try and get a signal and still will not get one.This just started about a week ago. Thank...
hi foxylady0415,
try and run the update and make sure its fully charged and try again...you can get the update HERE
download and follow the directions exactly, and make sure the batery is either fully charged or the gps is plugged in to a good charger.
let me know if you need further help
Bill
Standing Member of G.O.T.
Oct 21, 2010 | Magellan RoadMate 2000 GPS Receiver
Roadmate 2000 has suddently started giving me crazy directions. If I followed them, the routes would take me 30 miles out of my way.
  • Check first the signal. Make sure the signal is not weak. Because if the signal is weak normally thats what will happen.
  • Reply to this solution if you have questions.
Jun 12, 2010 | Magellan RoadMate 2000 GPS Receiver
Magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Jul 23, 2009 | GPS
Magellan roadmap 760
The Magellan 760 has been around for a few years now, and unfortunately, isn't one of the fastest units around when it comes to synchronizing to a satellite. I find with mine that the time it takes to lock onto a signal depends on several factors:
1) Having the GPS mounted in a way that allows the antenna to have a clear view upward 2) Having my vehicle in the open, so that the signal isn't impaired by adjacent buildings, overhanging trees, etc. 3) Being stationary while the GPS attempts to get a lock. It has more problems locking while moving. 4) Ensuring that the GPS is used frequently, as it loses its memory of what satellites it's synchronized with if you happen to be in a different place when you turn it on than the place you were at when you last turned it off.
Those last two points have the most affect on my GPS's performance. I find that by turning on the GPS and just parking in my driveway or parking lot for a few minutes will allow the GPS to acquire a signal in a much shorter time than if I start to drive immediately. While this will waste a bit of time on the front end, it does help you get synchronized more quickly
May 27, 2009 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan RoadMate 700
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
Keeps seeking but no GPS positioning
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Sep 06, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
451 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
