Question about Denon AVR-3803 Receiver
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I believe and they are conected to the cable DVR box. i'm getting no sound. Any thoughts?
    Novelist:
  • 87 Answers
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Posted on Jul 16, 2010
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
I need to plug in a Xbox 360 into a samsung flat screen t.v using the : red yellow and white . And the green red and blue . . how should i go about this .... because im not sure wherre the cords go exactly...
You will use the red and white connections for your right and left audio, those go into an"INPUT" on the TV, then you will either use yellow, or red-blue-green for your video, not both, either yellow, or red-blue-green.
Make sure you connect all cords audio and video into the same row or group of jacks on the back or side of your TV.
Good Luck !
Mar 16, 2010 | Samsung LNS2652DX 26 in. HD-Ready LCD...
Hello, Currently I have Vaio laptop connected to my Vizio 42" inch flat screen TV. There's no audio coming from my Vizio TV. So I connected an audio cable connected to the stereo jack. Where do I connect...
You need a 1/8 in cord on both ends. Normally, its an 1/8 inch audio connection in your tv to work with PC (the same connection as when you plug it in your comp) So u would need a wire that both ends are 1/8 inch (Headphone jack sized)
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Color in TV
I have the same problem. I had a tech guy come to the house and there is a part that needs to be ordered for it. If you have a warranty it is free but if not the tech guy said the part costs from $450 to $500.
May 09, 2008 | Vizio L32 32 in. LCD HDTV
Verticial Lines
i know some things you can try one thing is try to power cycle the tv your goona want to turn the tv on the unplug the power cord from the wall then with that cord unpluged hold down the power bottom for 30 seconds.then if the problem still happens try some different cords then try resetting all setting if u can reset all picture setting another thing u will want to try is see if it happens on like a dvd player or sometype of other source like video game and if none of these trouble shooting tips work. then you might want to buy a vizio.
Jan 11, 2008 | Televison & Video
Denon AVR-3803 Receiver Logo
210 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
