Question about Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive
The bios does not see the Western Digital Caviar SE16 500gb drive after I plug it in...what could be going on? Is there a power setting I don't have correct?
  • 487 Answers
Hi, on the rear of the drive there are a series of pins with a small plug coveing two; you need to remove the pin and alter the placement for either, master or slave depending on what you are using the drive for; you will see a small diagram telling you where to place the plug. Hope this helps
Posted on Jul 16, 2010
Windows7 wont read wd1600 caviar as a external drive ???
Did you install the western digital drive softare? There should have been a disk with the drive, which you run when you have installed the drive. It tells the computer there is a new hdd in town. If you don't have the disk, google Western Digital, find their website, and search for HDD driver software, with the model number of your drive. You should be able to download the drivers to your computer, and install them that way.
Nov 05, 2012 | Western Digital Caviar WD1600BB 160 GB...
I wish to us a WD1600 (caviar) hard drive fopr extra storage in my pc the drive came from my old PC there are eight pins to choose from. Where do I place the jumper?
Well, if this hard drive is SATA and looks like this:
Then you don't need to worry about the jumpers at all, the hard drive is ready for use in your PC.
However, if it's IDE, which looks like this:
You will need to move the pins to the "Slave" setting, and on Western Digital drives it is one set of vertical pins going away from the 4 pin power input, the above picture is set for Slave mode, and can be used as a reference.
May 05, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
My western digital wd2500jd does not get detected
try detect it from BIOS
if its not detected mean your western digital wd2500jd controller is need to be replace.
try ebay to buy its replacement.
just seacrh with keyword "western digital wd2500jd mainboard"
Mar 07, 2011 | Western Digital Caviar SE WD2500JD...
How can I clean boot record password
You have to clear this in BIOS. Power off you PC, change jumper on motherboard for you specific board (Have to look it up) place jumper setting where indicated 5-6, 6-7???, power on PC, at beep remove jumper and place back on original jumper setting. This should clear passwords.
Jan 11, 2011 | Western Digital Caviar WD400AB 40 GB Hard...
I would like to use my old 40 gb Western Digital Harddrive for a secondary data drive on my Desktop computer. When I hooked them both up and powered up the computer wouldn't boot, I assumed it was because...
http://www.lyberty.com/tech/hard_drives/WD_Caviar_WD400BB_specs/index.html
Above is the link to set the jumper on the 40GB to Slave.
Also, before it boots, try to get into the BIOS setting and make sure your compter can see both drives. If not, double check jumper settings for both drives. Turn off compter and change settings.
When computer can see both drives in BIOS, save it and let the compter continue to boot.
Hope this helps.
Jan 04, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
Is not being regonised
unplugg and re plug the hard drive and make sure that the pin out is set to MASTER! not!! cable select or slave! then open bios on reboot and see if it shows up in there
Jan 14, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Just buyed Western Digital Caviar SE WD1600AAJS 160 GB SATA
you have to enable the raid controller in the bios to see sata hdd nad have you pluged the power connector to hdd which is by the sata cable port then to your sata port in the motherboard, then install sata card drivers for your motherboard then reboot and after you have rebooted goto devise manager and see if it is reconised the driver if you have a yellow question mark then select it then right click then uninstall then click yes when removed driver goto the icon with spyglass and computer on and doubleclick on to search for new hardware once done reboot then your new hdd will be in the my computer icon.
hope this will help
Jul 08, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Drive has power but fails to come on
hi if try bios setting then setup it..
Open your hdd Drive change your jumper .....restart your pc put in Any OS Xp Driver...press ok enter 5 times if it boot then format & setup it....
Jun 29, 2008 | Western Digital Caviar (wd800lb) 80 GB...
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Western Digital Caviar SE16 (WD5000KS) (5000KS20PK) 500 GB Hard Drive Logo
333 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
