Question about Whirlpool Duet GHW9150P Front Load Washer
Code f 21 slow drain or stopped up . the drain lines are clear wh
I've checked the drain line and they are clear.
    Novelist:
    Champion:
  • 222 Answers
Did you check to see if it is stoped up between the tub and the pump socks or somthing stops it up somtimes also check that the pump is turning and is not stoped up.
Posted on Jul 16, 2010
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/geneva_f6ab09a476387fe3
Dec 11, 2011 | Kenmore Washing Machines
I need to clear the drain line on my Amana ARB1917 bottom freezer refrigerator. I've accessed the short tube that is supposed to move the water from the fridge/freezer to the drain pan ... it's...
The way to check that everything is clear pour some water over the evaperator coil in the freezer and see that the water drains very quickly. Also you could use a can of compressed air that you would use to clean the keyboadr and what not on your computer and blow it in drain and clear anything remaining
Gene
Aug 03, 2011 | Refrigerators
I have a maytag epic z and it suddenly stopped washing - I get an F-21 prompt. What does that mean?
F21 is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesnt solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Apr 09, 2010 | Maytag EPICz 3.7 cu. ft. Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 21 error code I came down with 1 minute estimated time remaining, and it was still spinning with soap and water in the machine. I checked again 20 minutes later and the water and soap was still in...
"F21" is a long drain error code. This is most commonly caused by something obstructing the drain pump, or drain lines. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
I would begin by checking the drain pump reservoir for small debris. You would be amazed as to what finds its way into these pumps. The link I provided also gives instructions on how to check the drain pump.
If you clear the drain pump and the problem still presists, verify all the drain lines are clear. If all these preliminary checks still result in an error code, more than likely the drain pump is damaged and requires replacement.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool elite
You have a plugged drain. You are going to have to remove the front cover. That has screws holding it in place. Once removed you will see the drain line and you need to disconnect it. Be careful though it will be full of water. Once you get the water out. You will need to clean the drain and the filter. This will solve the problem. Make sure unit is unplugged during this time
Feb 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
81 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
