Question about LG WFT1071TP Top Load Washer
Coin stuck inside spinner - LG WFT1071TP Top Load Washer
    Champion:
    Scholar:
  • 210 Answers
What is the spinner?
Posted on Jul 16, 2010
My LG top load direct drive had a coin inserted in its spinner. How do i remove it? Please help.
From what I can see, I would start by placing a piece of tape on the coin and on the drum (on the left side of the coin in your photo). You do not need to really press / seal the tape against the drum. I'd fold the very end of the tape over so it can be grabbed easily. This should keep the coin from falling behind the spinner.
Next, insert a straight blade screwdriver just above or below the coin (the wider the blade the better) and use it like a wedge. You can push the screwdriver tip in the gap to open up the space or gently twist the ***** driver just enough to pry the spinner away from the drum - slightly.
While maintaining pressure or the twist on the ***** driver - use you free hand the grab the folded end of the tape to ease it off the drum and pull the coin out of the seam. If you did this right, the coin should be on the end of the tape and you can pull out or release the twist of the screwdriver - and neither the spinner or drum will be deformed. Good luck!
Mar 16, 2016 | LG Washing Machines
Change in the waterpump
You can try disassembling the pump only sufficiently to get the coin out but if you go that far you might take a look inside the pump to determine whether anything else is stuck
Feb 18, 2013 | Haier HLP23E Top Load Washer
Money fell under the spinner
I take it that you mean that there is monetary coin or coins stuck between the Wash Bowl and the Spin Bowl. If the diameter of the coinage is greater than the Wash Bowl outlet, the coins will never find their way to the emptying pump of the machine, and will continue to rattle around inside. However any of the coins can enter the Wash Bowl outlet this could result in the water pump becoming jammed or damaged requiring replacement. I have solved this problem by removing the top of the machine (HOB) above the washbowl then completely removing the shroud over the Wash Bowl...then replacing the top of the machine firmly. By then turning the machine upside down, the coins will drop out and can be retrieved. Finish the job by returning the machine to the upright position.
Oct 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cant get middle coin in new super mario brosin w6-3
In 6-3: Go all the way to the right until you see a red pipe. Enter it and go to the right and go up. From the pipe you've exited out, move two pipes to the right and go down. It should be there.
In 6-6: Go to the right to the Spinner. Jump on it and then move right to another one. Jump on this one again and land on the right ledge. Another Spinner should be very near; jump on it without moving while flying and land on a ledge on your right. Jump up to see another Spinner; jump on it to go up again. While flying, go to the left to see a platform. There is the coin!
Hope this helps!
Jun 23, 2009 | Nintendo New Super Mario Bros. for DS
How to get past world 6 level 4 on super mario bros
I can help
I completed it all and got all coins.
OK are u stuck on the fire spinners?
U need good timing. Oh and you need to know how to bounce from the walls.
If u need more help tell me
Mar 12, 2009 | Buck Petz: Monkeyz House for DS
Front loader washing machine not spinning
I cleaned out the filter which had coins and gunk stuck in it.
Iinitially it didn't make much difference but eventually the spinner kicked in.
incidently, I looked at another site while I was waiting for a response from Fixya, which provided a list of potential causes and fortunately it turned out to be the first one.
Thanks for responding - I may indeed use your service in the future as I'm sure something else will stop working in due course. Bill
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Blockage? pump not pumping
yu should go ahead and check the pump chances are there is a sock or something else stuck in there keeping it from draining...its right on the bottom of the washer
Jan 30, 2009 | Fisher Paykel EcoSmart GWL15
Coin is stuck inside
where is this machine? apartment complex? YOUR private machine?
Dec 27, 2007 | Maytag MAH2400A Front Load Washer
LG WFT1071TP Top Load Washer Logo
106 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
