Question about Kolcraft Tender Vibes 18189-TX Crib
Can't put back together
I can't put the skirt back on
  • 7 more comments
  • nicks-gurl16 Apr 27, 2008
    how in the world do you put the thing back together?
  • angel4eva006 May 02, 2008
    i took the whole thing off i can not figure out what button go where or anything i cant put the skirt looking thing on
  • Anonymous May 17, 2008
    I took everything apart to clean now I can't figure out how to put it back together! I need an instruction manual!
  • nicolegus May 28, 2008
    I cleaned the fabric and now cant figure out how to put the bassinet back together I need a manual
    Im having the same problem I need a manual to put bassinet together
  • stefers Jun 11, 2008
    cant figure out how to put bck together . when i took apart to clean
  • melissa21 Jun 16, 2008
    i cant put the skirt back together
  • Anonymous Feb 19, 2009
    cant get basinett back together
  • Anonymous May 02, 2009
    cant put back together
It is very difficult. My parents and I spent about 3 hours on it, and my husband came home and did it in about 5 minutes. You have to actually put the hard-wood board and frame part in the liner. You have to pull it really tight, and the bit of printed material with the Warning sign should fold from the outside in. This puts the ruffle part close to the top--but on the outside. The buttons will snap all around, and the strappy things on the bottom hook around that bottom basket part and snap. You will be able to see the wood before you put the little mattress back in. I really hope that helps--we were so frustrated.
Posted on Jan 29, 2010
It seems backwards when you do it, get the mesh insets on either side and the ruffle turned the right way, and the top of it snaps onto the board that goes under the mattress, hope this helps!
Posted on Apr 28, 2009
I need help for skirt directions pattern #1300. I do not understand the directions to put ruffles together
Take the instructions and the project pieces to the local fabric store and ask one of the kind ladies if she will help you.
May 26, 2017 | Sewing Machines
Need to put skirt back on bassinett
sorry but never having seen one or had one guess you need to get the person that took it off to put it back on
Oct 07, 2015 | Baby Gear
How to attah table leg frame to table bottom panel?
Not quite sure what part(s) you're having problems with. But I'll tell you what I know...
There is a table top (a bunch of boards joined edge-to edge). Under this top is a skirt. The skirt is typically a box that doesn't need the table top for structural support - the legs are attached to the skirt (in the corners). Depending on how the skirt is designed, the legs may be removable (makes the skirt more complex).
Attaching the skirt to the table top can be done in many ways. The best way is to allow for expansion/contraction of the table top. The edge to edge combination of the table top makes for a larger expansion/contraction than the skirt. So the skirt should have a slot instead of a hole for a screw through to the table top.
If you just screw everything together, it will work. But if moisture and/or temperature changes, you may separate the table top, or joints in the skirt.
Apr 23, 2015 | Saws
Won't start
This engine may well have seized, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing and the machine will have to come apart to assess the damage.
May 16, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
How do you remove the front access panel to check for leaking?
should be able to either push down or up on skirt..has clips that hold it together bottom or top>>are longer shorter to allow movement
Dec 30, 2010 | Jacuzzi Amiga, Soaking Bathtub with...
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
Rear skirt on lawn mower flips under when backing up
Sounds like the skirt is too long for the cutting height you are using, either raise the cutting height or shorten the skirt. Remember it's a safety guard for trash kicked up when mowing!
Apr 11, 2009 | Craftsman Garden
How the hell does the skirt go on this piece of ****?
Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
Quetion about aftemarket side skirts....
honestly your best bet would to be installing the side skirts with pop-rivets. Get a manual pop riveter. You can purcjase this at any local hardware store, also you will need to purchase some pop rivets. Ask a sales associate what sise you will need, by telling them what you are riveting they should be able to help you find the right size and length.Start by marking exactly where your side skirts will be on the car. Make sure to align the skirts perfectly in mock up so you wont run into any issues with the door rubbing against the newly installed part. mark your holes for where you want to put the rivets placing one every 9 inches to a foot apart. You may also use fewer or more rivets it all depends on how secure you feel with your work. Next after all your holes have been marked drill holes in the spots that you have marked, this will allow you to lign your side skirt back up and mark the frame. Once the frame is marked you will need to drill the marked holes out. Be sure that the drill bit you use does not exceed the size of the stud on your rivet. This will cause the shield to seat wrong and make it that much easier to putt out of the frame. Finally after all your holes are drilled install your rivets and break off the studs. You should be good to go. Word of advice if your car is allready paintes and your side skirts arent, but you are planning to paint them after installation, DONT! drinn your holes in the kis sand any rough edges down and paint it will save you time and hassle in the long run trust me! hopes this helped
Aug 07, 2008 | 1999 Mitsubishi Eclipse
Kolcraft Tender Vibes 18189-TX Crib Logo
716 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
