Question about JBL BP600.1 Car Audio Amplifier
WANT A CIRCUIT DIAGRAM BP600.1 OR THE NAMES OF MOSFET TRANSISTORS AND THAT IS I would greatly appreciate QE SI ME NOT HELP ME IN ANY SIDE A THE NEED GRASI
If i can get a diagram for jbl bp600.1amp pls and ty
Posted on Feb 28, 2011
I've replaced the mosfet rjh3047 because short-circuited. the new one is gone as well shorted. thing else I can check?
you must have some diagram b) must test some around components like capacitor+diode+resistor+ic+Trafo , that will be in short circuit this will provoke the short in your MOSFET transistor.
God bless you
Oct 15, 2012 | Samsung LJ92-01393A BN96-04594A...
20 inch rca colortrak plus wont turn on.trying to figure out where power relay is on board. any help would be greatly appreciated thanks kris
Dear Kris
You check the out put voltage of SMPS
If OK then check the Horz. out put Transistor / MOSFET
Check the Horz. driver TR.
Apr 28, 2011 | RCA 20" TV
T1500-1bd burnt mosfet
First of all is the mosfet your talking about in the output section or in the power supply section? Most car amps use mosfets in the power supply section, some use them in the output section. To test the transistors in your amp, take a digital volt meter and set it to diode check. Then take the leads and put them accross the first and third legs of the transistors. Usally the red test lead on the first leg and black test lead on the third leg of transistor. If you get a reading of 000 then transistor is shorted. If you get a reading below 600 then transistor is on it's way out if not allready or it's next to a shorted transistor that is it's complimentry output transistor. comonly you will have 2 transistors working together, one NPN and one PNP per a channel, or 4 of them in a bridged type output circuit depending on the watts and how man channels your amp has. I was just looking at the specs of this amp and it's got me confused. It says it's a 2 channel but looking at all the info on different pages it says at 4ohm:200wattsx4 and at 2ohms:300wattsx4 and 1 channel mono 600watts into 4ohms. weird for a 2 channel. anyway that is how you test your transistors. Same way for the power supply section but, you will come accross a couple or more switching diodes that look like transistors and you will get a 000 reading when you test those like I specified. They rarely go out and most of the time there is only 2 of them. They will have a diagram like a diode on the front showing you which way the power flows. Let me know what you find out. Your amp should have went to protect mode if you smoked a mosfet.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Feb 08, 2009 | Audiofonics ADF-243 Car Audio Amplifier
Tv shut down and I found the HOT to be shorted.
this set is famous for defective flybacks. part number is 262342. replace the flyback
Jan 09, 2009 | RCA 36V430T 36" TV
Hej ku jeni bre qe spo folni a
qe bre ti ku je qe nuk po fol heheh ej nime kush je ti bre se nuk jam ka te njoh qy
May 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
JBL BP600.1 Car Audio Amplifier Logo
141 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Steve Sweetleaf
Steve Sweetleaf
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
