Question about Garden
I have a Black & decker-pressure washer and the problem is the hose was broken. How can i fix or where i can buy a new one?
  • 11,896 Answers
Duck tape if it's completely dry and extremely tight. Mabey epoxy but that might not be strong enough. I would just get a new hose at blackanddecker . com or ebay
Black & Decker - Dewalt DP352 Pressure Washer 4000 Psi Hose
$71.99 new - TheHardwareCity.com
Posted on Jul 16, 2010
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Apr 22, 2014 | Black & Decker 1700 PSI Electric Pressure...
Leaking water
You will need a new gun but if the hose is attached you will need that as well. As far as I know these small electric washers have the hoses and guns as one unit and repair is not an option.
Mar 12, 2014 | Black & Decker Garden
Black and decker electric power washer nothing coming out of wand all water coming out trigger.
Either the pressure tip or wand are blocked or the valve in the trigger is broken. Remove the high pressure tip and either try another tip or pull the trigger without a tip on the wand to see if you have the same problem. If available, try another pressure gun on the hose.
Jul 25, 2012 | Garden
Broken Edge Guide
The diameter of the Black&Decker GH400 edge guide is 1/8". I know because I have the same problem and a small piece left from the original. Trying to find a new one is quite the quest.
Apr 22, 2010 | Black & Decker Garden
I have a black & decker pressure washer model PW1600 and its not getting the high pressure anymore. any ideas
check the unloader valve (pressure relief valve) probably need to replace the o-ring. it should be on the side of the pump and have a large spring. just unscrew and replace.
hope this helps.
Sep 12, 2009 | Black & Decker BDP2600 Gas Powered...
When I connect the water hose to the pressure washer and turn on the water, the hose pops off.
Either the hose connection or the pump connection threads are stripped and will need to be replaced.
Aug 24, 2009 | Black & Decker Garden
Trouble with cleaning solution in my Black & Decker Power Washer
usually you have to lower the pressure at the lane for the detergent to come through as it works on a venturi principle.
can you twist or pull back on the lance to lower the pressure?
if you can take out the lance extension and run the machine you will see if that is tha cse as it should then pull deterrgent into the pump.
alternatively take the high pressure hose off the front off the machine and run it, this should also pull detergent in. if not you have an obstruction in the detergent pipe, blocked filter, regulator not open enough. or a worn injector.
Jul 19, 2009 | Garden
High pressure hose connection blew up. Fix? or buy new?
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Mar 11, 2009 | Garden
Garden Logo
262 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
