I have a Harmon Kardon AV-230 model that i purchased 7 yrs ago. The other day i was watching tv and all of a sudden the receiver shut off but the stdby button was lit amber color. I tried to turn it on and it wont turn on. So i had to do the system restart and it worked for afew days until 5 mins ago and now it wont turn back on. I have never had this issue before. I am wondering since i live in hawaii and the sun sets towards our windows if there is a thermal cut off switch that maybe causing it to shut down. Any clues?
    Brigadier General:
  • 8,546 Answers
You may be on the right track. Does the unit feel unusually warm when it dies? Keep it out of direct sunlight (this is ALL in the manual), away from humidity and moisture, avoiding drafts, dust and vibration and make sure it is well ventilated.
Also make sure you're not slaving anything that draws a lot of power from its convenience outlets on the back.
Posted on Jul 21, 2010
When i turn on my harmon kardon avr 165 it shows ''Protect'' and then it turns off again?? what can i do :)
I would try disconnecting the speakers, then turn it on. If protect still shows with no speakers connected, then it needs to go to the repair shop- Might be a blown power transistor.
Oct 24, 2013 | Harmon Kardon Harman / Kardon AVR 165...
How to connect the subwoofer to my Tv Samsung???
Most of the time there is a foldback of the left and right audio inputs of the subwoofer in that they use and sum the L and R audio and then filter the high end off. That means that the audio outs from your source be it the TV audio outs or a AV receiver that they can be Y corded to the sub woofer for that purpose.
Oct 01, 2012 | Harmon Kardon Harman Kardon Subwoofer Sub...
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
We are hooking up our harman kardon avr 2600. does the pvr & dvd player go in to the receiver then out to the tv?
only if the harmon kardon has video in (yellow) and video out. otherwise just the audio should go into the harmon
Mar 13, 2011 | Harman Kardon Audio Players & Recorders
Problem denon avr 1910
most electrical units have a fuse inside,try taking cover off and checking for blown fuse,or,take it to radio repair shop.My Harmon Kardon stopped after 3 years,and the report said the unit that failed was quite a common problem for the modern multi channel amps,quite cheap to fix..All my tips are free
Jul 04, 2010 | Denon AVR-1908
Harmon/Karden AVR 230 Surround Sound Receiver
Use your remote to get into the Menu. Look for something called audio, or audio properties. In there you can choose your inputs (sources) and output choices.
On the remote itself, there should be a button called input, or source. That would be for things input to the TV.....such as dvd, vcr.
Apr 06, 2010 | Harman Kardon AVR 230 6.1 Channels...
I have sound when I play the dvd or the cd player
Sounds like the setup info got scrambled in the receiver. Re-program the TV input...from optical or coax or whatever way it is going into the receiver.
Harmon Kardon AVR 230 produces no sound and no monitor out.
you do not have +17v and -17v on transformer board the top two fusible resistors are blown and the cap between them needs to be replaced as this cap probably shorted and caused resistors to blow. easy fix
Jun 04, 2009 | Harman Kardon AVR 230 6.1 Channels...
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
48 people viewed this question
 Grubhead
Grubhead
