Question about Epson Stylus CX4200 All-In-One InkJet Printer
How to change ink in a canon cx4200
How to change ink cartridge in a canon cx4200
  • 4,472 Answers
Just follow this link to view the user guide available from epson. Then click on 'removing and installing ink cartridges' link.
http://files.support.epson.com/htmldocs/cx42__/cx42__00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=maint2.htm#wp1020194
If you have any issues let me know.
Thank you,
Lee
Posted on Jul 16, 2010
I change new innk still not printting
Please change your ink with the cartridge changing utility,which is available in your printer property.
JAIN_IT {INDIA}
Sep 15, 2010 | Epson Stylus CX4200 All-In-One InkJet...
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Can i print without color catridges
you do need both cartridges in and with ink or the printer will not print to prevent damage to the print heads from running dry. The printer normally uses a small amount of coloured ink to "tone" blacks but if you leave it set to Black only it won't do this and in the future you should only have to replace the black cartridge.
Chris
May 21, 2009 | Canon PIXMA iP1600 Printer
Problem with printer DX4400
If it's like my CX4200, save up to buy a Cannon. It's the most economical with ink. I was told that to save ink:  Keep the machine on, if you use it a lot. The charging, on activation, drains ink. Realize that printing PDF's and Web Pages use the color cartridges, even if there's no color on them. Word documents, text-edit, etc are the only things that use only black (only if they don't have colors, of course) because otherwise things are read as jpgs.
In some way, the printer keeps count of the documents so that, yes, the cartridge can be read as empty when it's still sloshing with ink. That means printing on low resolution, toning down bright colors,  might not really have a savings on ink.  So try to trade in for a Canon or HP. They let you choose to do only grey-scale, for one thing. And one can do printing on very low, and no ink, if you choose.
Apr 06, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Ink cartridge changed but computer will not recognize it has ink
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Aug 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Changing the ink cartridge in Epson Stylus CX4200
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
My epsonstylus cx4200 wont print with black ink.
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Feb 09, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
78 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
