Timer set on remote, cancels out after use
Mitsubishi Air Con MSZ-GA60VA
  • terrytiger Apr 21, 2008
    Why does the remote drop the timer settings after the first operation? Other brands will retain the timer settings and enable the timer to operate over a 24 hour period. Am i reading the instructions incorrectly? If not, can I get a different remote that will do what I want?
I have discovered that a 7 day timer is available, but it is a fixed and separate box and will need to be programmed into the wall unit, at a cost of $500.As i am a pensioner and unable to afford this cost, I must persevere with the remote I have. Why can't the so-called experts provide a top of the line product in the first place?The last aircon unit I had was a Fujitsu, and that DID Have a very good remote enabling a programme of ON - OFF, On - Off in a 24 hour period. Thanks for trying to help.
Posted on Apr 22, 2008
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
I have a Mitsubishi mini split system heat pump model MSZ-A12NA. The problem is the wireless remote has been lost. How do I get another one? Or, can a regular hard wired heat pump thermostat be used? I...
just lift the filter panel on front of indoor unit and turn it on manually,remember this just sets the a/c to 24 deg,the unit decides whether to heat or cool it to 24 deg....at least it gets it goin so u can order a replacement
Feb 21, 2011 | Mitsubishi MSZ-A12NA Air Conditioner
I have a error message f1 on my air con
F-1-Noc ommunicationbetween indoor and outdoor.Check connections and LEDs. If OK replace either main or fan PCB
Jan 15, 2011 | Mitsubishi MSZ-A15NA Split System Air...
Mitsubishi msz-ga60va not cooling. Did same last year then righted itself. Left light is flashing. and no cool air. Please help.
You didn't give any error code. But, still, I hope unit need complete service. Do it and check again.
Jan 07, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Dear Experts, My Air con is not working, cant be turn on, there is blinking on the power . Tried to cancel the timer, it didnt work. Thanks Sri
To cancel the timer remove batteries in remote and reset it. and also reset the power with a/c unit. now you can operate with your remote.
Dec 30, 2010 | Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Sometimes the mitsubishi Mr.slim unit is automatically fully off and an icon is on the remote control is blinking..what is the problem?
Check for timer setting you have done. If it is, reset the power to unit and also remove battery in remote and reset it. If still problem write again plz.
Dec 13, 2010 | Mitsubishi MSZ-A12NA Air Conditioner
I have 2 units of 2 hp mitsubishi split type air-con. both units are having problem with timers. the timer will blink after 20 to 45 minutes of operation and then it will turn off by itself but the light...
the timer may have been activated at installation or by someone not fully conversant with the operation
use the remote and follow the instructions in the owners manual to turn the timer off
Sep 06, 2017 | Mitsubishi MSZ12UN Air Conditioner
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
