Question about Fisher Paykel EcoSmart GWL15
Only cold water
Please help. no matter what button i push, only cold water is put into the tub to wash. The hoses are attached, i have hot water in my hot water tank, i unplugged and replugged the plug. What next? Thank you!
  • 472 Answers
The solenoid that operates the valve for the hot water has probably failed.. A common fault on all machines.
Swap the wires from the hot inlet to the cold inlet and see if the hot water flows then. To check the cold tap, you will have to set it to hot, and to check the hot you will have to set it to cold (since the wires are around the opposite way) on the control panel.
Check power board also, there is a fuse that allows power to goto the inlet valves, though in your case seems to be OK as you are getting cold water still. Your particular model may have a seperate fuse for each solenoid though.
New inlet valves are available from any white goods repair shop. They come with a solenoid that operates the valve.
If this is still under warranty, then a call to F&P will have it fixed in no time. Make sure to have your serial number and all other info ready when you call.
Posted on Apr 21, 2008
Front Loader W'pool # GHW9400SUO throwing codes F/H. I know it means water inlet, but can't seem to figure it out. I have changed both hoses. They are free and clear, but only runs for a minute...
hi ,,inside the water vavle theres screens unplug unit stick a little screw drive in each vavle,,,hold up to light to see if clogged,,,if clogged wash out and replace...good luck
Sep 03, 2011 | Whirlpool Washing Machines
Hot water won't run into washer
G'day. The hoses from your laundry taps hook up to your machine onto what are called solenoids. These are like electrical taps. The machine decides when to turn these on and off and in what order via the timer and depending on what modes are selected. Generally there is a hot and cold solenoid. If you have both hot and cold hooked up to your machine, you can simply swap these hoses around (put the hot tape on the cold solenoid and vis-versa) Then when you select cold, you'll actually be getting hot. Some new machines heat water internally like dishwashers, and they only have one solenoid. Again if you put the hot tape only on, you will get hot water with cold selected. In both solutions you are losing the option for cold or hot cycles with a click of a button - now you must swop hoses...
Aug 17, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
No/low water inlet. Diag mode both ht & cold lights flash
first test water valve ohms reading, this fault could be either control module or water valve.first open top panel to see valves. turn power off to unit. try putting the hot water valve wire to the cold and the cold to the hot. hopefully they will reach, sometimes they dont. then put panel back on with loose screws. turn power on , select low water ,and hot fill.push start button but make sure your hoses r connected and turned on. the reason i"m telling u how to do this is to eliminate the control board as being faulty if the cold water comes into unit then the problem is your computer, if no water comes in it is your water valve.i hope this helps if u still need help please reply
Apr 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
NEC NW-452 Washing Machine will not run a Hot Wash
by memory it is located at the lop of unit, where u attach the inlet hoses 2 the machine. u need to remove inlet hoses first with water turned off, then undo 2 screws at back of washer holding plastic panel that covers water valves and electics. it unclips off, i always have trouble myself. once u have that panel off remove wires to hot valve ( that is the 1 that had the hot water hose attached to it) put your tester on the terminals. if u get a different continuity reading compared to your cold it is faulty. if it is the same your computer at the front of unit is faulty.see how u go but remember turn off the power b4 u work on it! dont want any acciedents. please reply back for more help. good luck!
Mar 10, 2010 | Washing Machines
No hot water
Is the little screen in your hot water line clogged? (not the hose - inside the connection on the washer where you attach the hot water) Please check it.
Jan 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Its leaking water while the washer is washing
Hi
If your washer leaks every time you run it, then check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Oct 16, 2009 | Whirlpool Washing Machines
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
No hot water reaching the tub
hi thanks for the question if you cleaned the screen and no hot water i would replace the water valve thanks the appliance doc
Sep 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Fisher Paykel EcoSmart GWL15 Logo
81 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
