Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
The mower electronics and flywheel seem to be in good conditioin has a new battery but will not start. Filled it with Gasoline could it be a Spark Plug problem? Fuel line is not stopped up but the engine just will not fire and stay running. Any suggestions? spark-plug no good?
Check mag.
Posted on Jul 16, 2010
Exmark Walk behind will not start.
Sounds like a bad flywheel or there are usually two magnets on the inside of the flywheel sometimes these magents fall off and with out they magnets you will not be able to produce the forces to start the mower hope this helps
Apr 26, 2014 | Garden
B&s engine on mower turned upside down, won't start now.
Take the spark plug out, turn ignition key or pull rope until the engine turns over several times. Let it sit for about 5 or 10 minutes and repeat. Replace the spark plug with a new one. Make sure that your crankcase is not over filled or under filled with oil, and make sure that there is plenty of gasoline in the tank. Make sure that gasoline cap and oil cap are on "securely". Now try to re-start. (The engine may smoke for a while, but it should clear up in a few minutes).
Nov 27, 2013 | Craftsman 16-gal 6.5-peak hp Wet/Dry Vac...
Just mowed and it made a noise, will not start getting spark to plug added starter fluid still will not start
if it made a noise from hitting something check the key on the crankshaft where the flywheel meets
May 20, 2012 | Garden
Briggs & stratton I have an older craftsman lawn tractor. 16Hp cast iron sleeves and flywheel, electronic ignition, no points, 24 yrs old. while using it went dead. no spark whatsoever, bought a new...
You bought a new ignition coil, how far from the flywheel was it mounted? Did you replace the spark plug?
I hope you get the old machine running soon.
Aug 12, 2011 | Garden
I am not getting any spark at the Spark Plug. I sanded all the magnetic parts on and in the flywheel. I have a new battery and it's fully charged. I checked the ignition switch with Electracal...
if the spark plugs are good then you will need a new magneto/coil. I am assuming all the safety switches are good, as this would also cause the mower not to start/spark. Hope this helped Tim
May 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I can start my craftman 6.5 ,21"mower mulcher. Spart plug is new.Gasoline is fresh.
Does the mower have spark to the plug? Remove the spark plug & reinstall into spark plug wire. Next you will need to get spark plug electrode next to a metal object on the mower engine & pull the cord & see if there is a spark-(do not hold onto the plug with your hand when doing this as you will get a jolt if there is a spark)-if there is no spark then chances are that your flywheel is rusted where coil gets its signal from or you have a bad coil itself. If there is spark are you getting gas to engine? Try a small amount of starting fluid sprayed into carb filter & see if it will run, if so could be a blockage in screw that holds carb bowl on-(has a small hole in the very bottom)-and bowl probably has sediment in it also. Be careful when removing carb bowl & in most cases seal can be re-used.
Dec 20, 2010 | Garden
I have a new Weedeater One 190cc 26in blade riding mower and during my 2d use it ran for approx 15 mins and I shut it off and when I attempted to restart the starter kept turning but would not start. I...
Check for spark and gas. If adding a few teaspoons of gasoline to the cylinder allows the engine to run for a few seconds, then you know that the ignition system is fine, but there is a blockage of gasoline to the engine.
Aug 21, 2010 | Garden
22'' recycler won't start
TRY A SPARK PLUG, MAY HAVE GOTTEN SOME WATER, MAY HAVE TO CLEAN OUT CARB
Sep 20, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
62 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
