Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Resetting lamp meter to 0
I have tried over and over the step of holding down vol- and the play button for over 5 seconds. is there something that i am not doing right
TO RESET THE LAMP TIMMER PRESS THE VOLUME DOWN BUTTON ON THE FACE OF THE TV AND THE OK BUTTON ON THE REMOTE AT THE SAME TIME FOR 6 SEC.
Posted on Apr 29, 2008
Reset lamp meter on panasonic pt 56lcx 16
Turn on the projector MENU- OPTION- LAMP RUNTIME- Press and hold the ENTER button for 3 seconds. Turn off the power.
Dec 07, 2013 | Panasonic 2 Projector Lamp
Describe your Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Problem: Need to reset timer light--how does one do that?? We got the new lamp installed but it keeps blocking the screen telling...
Hold VOL - on the TV then aim the remote at the TV (watch so that your arm doesn't block the remote signal and press PIP or the SPLIT button. Do this together for at least 5 second. I hope this helps.
Mar 18, 2010 | Panasonic PT-60LC14 60" Rear Projection...
How do i reset the hour meter on my panisonic
RESETTING LAMP HOURS
Consult Your owners Manual but this works for most Panasonics
Turn on Power
Press and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 23, 2009 | Panasonic Televison & Video
Need to reset hour lamp meter and held soen vol.-
Try holding down vol down on the TV and PIP/ play botton on the remote for 7 seconds. Their customer support should be able to help you too.
Oct 08, 2009 | Panasonic PT-43LC14 43" Rear Projection...
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
How do i reset the Hour meter on a PT-52LCX66-K
1. Turn the unit ON. 2. While pressing the [VOL-] button on the projection display, hold down the [0] button on the remote control at the same time for more than 5 seconds. 3. When reset procedure is completed, the following message is displayed on the screen: "LAMP TIME WAS RESET TO 0"
Sep 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-40LC12
hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Oct 29, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Resetting lamp panasonic PT40LC12
Jan 06, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
