Question about Wanlida Group Wanlida/Malata Combination 15" LCD TV/DVD Player
Malata DVP 892 hookup problems
TV pictures is flashing and jumpy in black and white. Try to use HDMI and hookup sound system. I have sound but no picture. Please help.
  • edmund75 Oct 05, 2008
    I tried to use VGA to hook up the system Same problem ?? Sound system Working, But NO image? TV display VGA no Signal? Please help???
I had the similar problem at first. You need to use another disc before you can configure the video output. Make sure you enable the HDMI output.
Posted on May 29, 2008
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
I have a Malata DVP 890. I pressed a button on the remote (it is in Chinese) and the crenn dissapeared. I can get sound from the DVD if I use the red/ whiit and yloow plug connections. Nothing with...
unplug the unit for about 20 minutes. This should allow the unit to go back to it's factory default settings.
Switch the TV to the HDMI input. Turn the TV off - hook the unit up with only the HDMI and turn on the TV.
If all goes well, the TV should signal the DVD player to turn on.
If not, wait about 10 minutes then manually turn on the DVD from the front panel (not the remote)
This will usually fix you right up.
Mar 08, 2011 | Televison & Video
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
No sound when using an hdmi
Even with HDMI, you still need either the red and white audio cables or the Optical fiber hookup.
Jun 06, 2010 | Televison & Video
Sony DVP-NS77H No outout
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Mar 16, 2008 | Televison & Video
Hookup
very simple , just made sure dvd output hooked to the input of your tvs and same color ,jack to jack,you know, yellow to yellow,red to red ,white to white.But I suggest you use a s-video jack(all black). instead of the yellow composite ,or RCA jack,which give you a better picture,and if you have a the component jacks (red, blue , green)on both machine , that will give you the best picture, but remember , you still have to connect the red(right channel,+))and white(left channel,-)cable to have sound coming out from your tv.You will need a s-video cable or component cables for those option I suggested.
Nov 17, 2007 | Sony DVP-NS55P DVD Player
DVD Picture Scrolls
THE RESET CODE- follow these steps
OPEN THE DISC DOOR, 00001, PRESS CLEAR, TURN DVD OFF, THEN ON AND IT WORKS AGAIN!!! YEA!
THANK YOU THANK YOU THANK YOU> that worked great!
Aug 23, 2007 | RCA DRC247N DVD Player
Wanlida Group Wanlida/Malata Combination 15" LCD TV/DVD Player Logo
170 people viewed this question
Top Wanlida Group Televison & Video Experts
Are you a Wanlida Group Televison and Video Expert? Answer questions, earn points and help others
