Question about Lexmark X4270 All-In-One InkJet Printer
The power light and the copy, scan and fax lights all come on and stay on and I cannot use the printer. I have to unplug it printer and plug it in again in order to print. Now the lights stay on all of the time. When all 4 lights are lit at the same time, I cannot print. Is there anything I can do to fix this. I've had the printer for about 3 years now, it still prints fine, but it is becoming more or more difficult to use it. Is there anything that can be done to fix this problem?
    Genius:
  • 1,087 Answers
Remove the cartridges from the printer then close the cover. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord plugged in to the power source. Bypass any surge device or power strip, plug the power cord straight to the power outlet in the wall. Wait at least 30 seconds before plugging the power adapter back in the printer. If all the lights still come steadily on, it's a hardware problem. If not, when it's ready, reload the cartridges. Let it print the alignment page. Then check if problem persists. If it does, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Posted on Jul 17, 2010
Message on HP officejet 5610 All in one Error 0xd05d010d and on button,copy,fax,scan and alert yellow light keeps blinking on and off "tried reset the power cord still givwing same problem.Please help
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark x7170 all in one won't copy or scan starts to but stops
It could be a scanner hardware problem. Try to unplug the printer from the power source to reset it. Wait at least 10 seconds and then re-plug the printer back into the power. If problem continues, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Jun 29, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP 3310 printer will not scan a fax or slides
no problems man
:just take out the catriges..plug outthe power cable ....then plug it bacvk in after 20 secnds,the printer will ask fr printer catriges ,puthem back in and try to perfom fnctions ,still problem persists ,follow following steps
:just go ahead and take ou the power cable
and press and hold # and 3 fr 30 seconds
while pressing them plug in the power cable
:similarly perform with # and 6
:ur problem will be resolved
Jun 28, 2009 | HP Photosmart 3310 All-In-One InkJet...
Lexmark x7170 will not copy
unplug the power pack in the back for about 30 seconds the plug back in
Nov 22, 2008 | Lexmark X7170 All-In-One InkJet Printer
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer does not power up
None of the leds are flashing or indicating the power.
First Possible solution is change power cable or put the one which is already working Cable. If Its not getting power Check the fuse of Printer. If nothing Works Consult to service center as it seems to be under Warranty before doing any manipulation in the circuit.
Regards
Rafique
Mar 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
X4270 Printer
i had the same porblem and the nice people at lexmark told me how to fix it. First unplug your printer. second.. hold the stop/cancel button while you plug your printer back up..keep holding the stop/cancel button and you will see a message that says erasing memory. the fax, copy and scan lights should flash and only the fax light will be on. That should do it but you will have to put your personal information back in, like your speed dial numbers, etc.
Sep 18, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
