Question about Buffalo Technology (HD-HB250U2) 250 GB Hard Drive
I have a buffalo external hard drive HB250U2-WR connected to the USB port of a laptop running Windows XP Home OS. When I turn the hard drive on, the "Power" indicator light on the front panel turns GREEN. The Access indicator light on the front panel is "Red". Also when I turn this unit on, I do not hear the usual drive clicks as we hear when you start a computer. Any suggestions? B. S. Mani solididea@aol.com
  • Buffalo Tech... Master
  • 6,487 Answers
Base from the description of your problem, what we can do here first to isolate if this is a hardware failure already is to connect the drive to a different USB port preferably to the back USB port of your desktop and then restart the computer while the drive is connected to it and if still same problem next thing to do is to try a different USB cable to check if this is only a cable problem.
But if still same problem the next thing to do is to connect the drive to a different computer and if still wont be recognized by any computer the last thing to do here is to take the drive out from its enclosure and connect it directly to a desktop computer and if you don't have any experience with that better ask someone to do that a computer professional to avoid further damage to the drive and to increase the chance to recover the data from it.
Posted on Jul 16, 2010
Cannot read or reformat my 500gb buffalo external hard drive
download Acronis Disk Director Suite via torrent. install the program. open the application. locate the drive that is not working. usually its labeled "unallocated". click on the "Acronis Recovery Expert" button. and again select the drive you want to recover/fixed. there are instructions on how you want the program to run its recovery. its pretty simple. bare in mind before running the application. your hard drive should be connected directly to your PCs USB port and not by any hubs. by this. your computer should be able to read your HD again.
Jan 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
I have a buffalo external drive. The last time it works is on my auntie's mac laptop, message prompt that i have to reformat the disk. It made me think that files are corrupted. I remove it hoping that...
If the Buffalo had been formatted on a MAC their file format is HPFS and is not compatible with Windows. To be able to exchange data between the Mac and Windows the Buffalo external drive needs to be formatted on Windows XP in FAT 32 (not NTFS). Then the Mac can read and write data on this external drive as well as Windows XP.
Jul 13, 2011 | Buffalo Technology Computers & Internet
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
HDD is not dedected.
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Jun 22, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Retrieving data off an external hard drive
You can and there is no need to install drivers, except the drive has any special features.
Apr 19, 2009 | Computers & Internet
Cant find Buffalo ministation in my comp after connecting it
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Mar 25, 2009 | Buffalo Technology 320GB MINISTATION TURBO...
Windows will not boot
Your PC will be set to boot from USB first. Go into the BIOS and set the PC to boot from hard disk first. Respond here if you need to know how to do this.
Feb 06, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Failure to start up
If the drive clicks and whirs and repeats, then I'm afraid it is dead. The only way to get any data off it will be to contact one of those expensive data recovery companies. Sorry!
Jun 26, 2008 | Buffalo Technology (HD-HB250U2) 250 GB...
Buffalo Technology (HD-HB250U2) 250 GB Hard Drive Logo
105 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
