What is the part numbers for the CRT boards in a RCA D61W20 tv?
  • 11,896 Answers
264118
Posted on Jul 16, 2010
  • 4 more comments
  • martysguns Jul 16, 2010
    Is this for the Red Green and Blue?
  • Nate Stansfield
    Nate Stansfield Jul 16, 2010
    Yes it is. All have the same part number.
    If you get them at the partselect . com site, they all have a different number
  • Nate Stansfield
    264118
    Green Cathode Ray Tube (CRT) Board
    partsearch . com
    264118
    Are these easy to put in? Do I tell them I need one for each color?
  • Nate Stansfield
    They are not to hard to put in. Just reconnect everything exactly the same. You should get one of each kind
  • Nate Stansfield
    Nate Stansfield Jul 22, 2010
    Not a problem! Thank YOU for using Fixya! Come back anytime!
The tv i have is a RCA D61W20 and it will not come on . the power light goes on and off three times and nothing
Problem with main deflection board,bad electrolytic capacitors/Hi voltage circuit has bad connections,common to those RCA tv's.
Mar 22, 2010 | RCA D61W20 61" Rear Projection Television
Who does in home TV repair have an RCA D61W20 or can it be done m
The most obvious item which is causing your problem are the 220K ohm 1/4 watt resistors on the convergence power supply board. There are four of them RP10, RP11, RP12 amd RP13
Jun 18, 2009 | RCA D61W20 61" Rear Projection Television
RCA D61W20 Projection TV
On the Deflection Board CK 3 capacitors cp150 2200uf 16v cp114 cp120 220uf 35v If cp 150 is puffed up top then it is bad so replace all 3 capacitors. Resolder all pinns on FBT too. and make sure second ribbon connector is in good.
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
3 green lights flashing on rca d61w20
On Deflection board cp150 if it is puffed up on top it is bad ,3 capacitors cp114 cp120 they are green with gold writing on them But; if cp150 looks ok Then you have problems in SSB board its the one that has tuners on it/ where you hook your cable too. The board to the left of it is the deflection board.
Dec 23, 2008 | RCA D61W20 61" Rear Projection Television
D61W20 RCA, Red Screen and then shuts down
sounds like the Red CRT (tube) has shorted. You can test by removing the RED crt circuit from the end of the RED tube and making sure it isnt touching anything try powering up the set. If it comes on and doesnt shut down the red tube is the problem and will need to be replaced . expensive part to replace the Red XRT will be over 300 and at least 2-3 hundred to have it installed unless you know someone who can replace it for you.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
D61w20 big screen tv
You will need the service manual to be able to properly align the new tube after installation, that will also give you important info such as discharging the old tube as well as removal instructions. Post the chassis number on your set and I can post the link to get a good service manual if you would like. rca are crossed by chassis number that should be located on the tag next to the model number
Mar 20, 2008 | RCA D61W20 61" Rear Projection Television
Blown tube?
tube replaement in these units are extremely labor intensive. shadow may mean a bad focus pack or it could mean a bad tube or bad crt board. but i would suggest geting a tech to look at it
Mar 12, 2008 | RCA D61W20 61" Rear Projection Television
Tv D61W20
so basically your power supply is out?
Nov 27, 2007 | RCA D61W20 61" Rear Projection Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
