Question about Sharp XE-A402 Electronic Cash Register
How to install paper rolls - Sharp XE-A402 Electronic Cash Register
  • 360 Answers
Hello pls tell me what is the model
pls download operatinon manual for solove this matter
Posted on Jul 16, 2010
Ricoh 240w cannot set paper tray error is not resolve any idea quick response required thanks.
SP 1960 Optional Paper Setting Enables installed options: Roll feeder (1 or 2 rolls),
paper cassette. This setting is not necessary if no
paper feed options are installed. (The default setting
is for the manual feed table.)
OR
BAD PAPER SET SENSOR
The paper set sensor detects the leading edge of the sheet. This switches on the drum motor, main motor, and registration clutch.
OR
Mar 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    I have a VeriFone Omni Vx510 - I keep getting a paper out message when trying to process a transaction. There is paper in the machine.
    If the printer does not work properly:
    • Check battery status or terminal power connection. The printer will not print if
    there is an insufficient charge remaining in the battery to complete the print
    operation. (For Vx610 terminals only.)
    • Check if the printer is out of paper and that the roll is properly installed. Open
    the paper roll cover and install a new roll of printer paper or ensure that the roll
    is feeding from the bottom.
    • Verify that the printer roller and paper roll dust cover are properly installed.
    • If the problem persists, contact 775-358-2922 hope this help : - )
    Sep 13, 2011 | VeriFone (M19755014US1) Magnetic Card...
    How can I change the paper. I cannot find the correct slot to install the new paper roll
    Press down on the button located on the side of the terminal to unlatch the
    paper roll cover, then lift the cover up and back
    Remove any partial roll of paper in the printer tray by lifting up
    Loosen the glued leading edge of the paper or remove the protective strip
    from the new roll of paper. Unwind the paper roll past any glue residue.
    Hold the roll so the paper feeds from the bottom of the roll
    Drop the paper roll into the printer tray.
    Close the paper roll cover by gently pressing directly on the cover until it clicks
    shut, allowing a small amount of paper past the glue residue to extend outside
    the printer door.
    To prevent the paper roll cover from damaging the print roller, always gently press
    down on the printer dust cover to close it.
    g+ypssoexzf1qaaaabjru5erkjggg==
    Mar 18, 2011 | VeriFone Omni 3700
    Display H and do nothing and till left open . can not close the till
    hmmmm are you try to install new paper roll?
    the paper feed arm didnt lock
    open printer cover and again install paper roll
    and close the printer arm
    then press cl key
    Sep 26, 2010 | Sharp XE-A402 Electronic Cash Register
    Changed rolls of labels on Zebra GX 420T and now nothing prints
    Were the new labels thermal paper? Thermal printers need specially made paper to work right.
    May 28, 2010 | Zebra LP 2844 Thermal Printer
    I ran out of paper and purchased a new roll of paper. I do not know how to install the new roll of paper.
    Just drop in, the paper needs to come toward you from the bottom and just past the paper cover once closed. If you have a paper roll spindle, insert and line up with the spindle guides on the machine.
    Mar 20, 2009 | VeriFone Omni 3200 Printer
    Panasonic kx-fp155 not printing
    problem is not clear.u change fax roll when it was finished.if fax was printing before ending roll .i think u have installed roll with wrong side .thermal roll only prints with one side which is coated .just see inside machine there will bi a paper for installing roll direction.if not just check thermal head .clean it check its supply.or just replace.it mian jee
    Jan 13, 2009 | Panasonic KX-FP155 Plain Paper Thermal...
    Change paper
    Paper roll installation is deceptively simple.  No need to feed paper through any slots inside the machine as you might expect.  Just put shiny side of paper down, feed edge of roll out of machine and under the roller that is attached to lid, and that is all there is to it!
    Oct 28, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
    Frequent Paper Jams
    The only suggestion I could make may be obvious but my experience has taught me that you need to make sure the paper is installed correctly, especially with double ply paper. We have learned that the yellow receipt copy ply must be attached properly to the green roller so that the double ply paper from the roll feeds correctly through the print roller. Also make sure the double ply roll paper is not loose coming off the roll that feeds to the print roller.
    Nov 20, 2006 | Ithaca (93+PRJ11) Matrix Printer
    Sharp XE-A402 Electronic Cash Register Logo
    53 people viewed this question
    Top Sharp Retail Supplies Experts
    k24674
    Electroboy
    Electroboy
    Patrick Tinashe...
    Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
