I have a set of Roadmaster rts 3000's which is composed of two subs I believe and two tweeters. They both have an 8 ohm impedance. Now I would like to wire the two pair together to have a stereo speaker set. How many volts will I need to run the two assuming I build my own amp?
  • 238 Answers
SOURCE: KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Posted on Jan 12, 2008
ctf1800
  • 4402 Answers
SOURCE: ipod headphone
http://www.ehow.com/how_114206_replace-headphone-plug.html
Posted on Jan 17, 2008
Benimur
  • 6966 Answers
SOURCE: SP-UXV30 speakers
Offhand, the tweeter can be rated similarly to that of the woofer but not lower than 26 watts. I think your concern should also include the physical mounting and size since most branded units would be using proprietary components/parts and are not readily available.
Most electronics parts store would be carrying "generic" tweeters and "as per sample" would be your best basis. If I understand it right, **** Smith in Australia would be similar to Raon Stores in the Philippines or Akihabara in Japan.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 25, 2008
  • 12 Answers
SOURCE: how do you make two dvc subs run at one ohm and put them to a 2 ohm mono block
Make sure your amp is one ohm stable. If you wire the subs at one ohm and the amp is not a one ohm stable you run the risk of blowing the amp if not both the amp and the subs
Posted on Oct 23, 2008
etirbynnor
  • 655 Answers
SOURCE: Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Posted on Jun 03, 2009
Using POLK AUDIO sound bar 3000 subwoffer on other systems
Yes providing it is the same impedance . EX if it is 8 ohm then they all have to be 8 ohms. Same goes for 4 ohm, 16 ohm etc.
Dec 16, 2014 | Polk Audio Surroundbar 3000IHT Home...
What is the impedance of the midrange speaker and the tweeter speaker in the Pioneer cs r5100 ? I have the crossovers and the woofers I use for my front channels (L&R)
If you are running three 8 ohm speakers in parallel then the total impedance would be 2.667. If running two 8 ohm and one 6 ohm speaker in parallel you would have 2.4 ohms. This will burn out your amp pretty quick. And very possible won't play at all. Though I have never attempted to play a home amp down that low in ohms. Guessing you may have an older model Denon type amp.
Aug 01, 2014 | Pioneer Audio Players & Recorders
Impedance setting on Yamaha AV Receiver
Hi. You can always use a Receiver with an output impedance that is lower than the speakers input impedance.Problems arise when you try to use a Receiver with a higher output impedance than the Speakers input impedance.
Receiver 6 ohms speakers 8 ohms......YES..
Receiver 8 ohms Speakers 6 ohms.......YES, WITH CAUTION
Jan 15, 2013 | Yamaha RX-V673 7.2 Channel AV Receiver...
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
What size fuse do i need to use for my speaker protection kit
This will be based on the 501 model as you did not give a model Also I am assuming speakers are 8 ohms which I have no firm information for the Tannoy, but they should be marked when you open the unit. We are allowed 40 watt RMS for the woofer and 20 watts RMS according to the specs. They do not tell us what impedance the speakers are so we will do calculations based on 8 ohm speakers... if yours are different, then recalculate; P = I^2 * R so for 40 watts and 8 ohms then I squared = 5 or the current is about 2.3 amps max... You COULD use a 2.5 amp fuse, but if they were my speakers I would use a 2 amp fast blow which gives a bit of margin for the woofer. Now for the Tweeter we have I squared is 20/8 so this comes out I squared equals 2.5 or taking the square root we have 1.58... you could use a 1.75 amp, but if they were mine, I would use either a 1.5 amp or even a 1 amp as the tweeters seem to get blown in these. ALL of these calcs are based on the specs of power for the 501 model and ASSUME 8 ohm speakers... Recalculate if your units have different impedance thaan the assumed 8 ohms.
Jun 22, 2011 | Tannoy Studio Monitor Speaker Protection...
Hi i am looking for some motorola tweeters for dj speakers do you still do these
If you're looking for new tweeters, I'd start at e-bay, see if there's any that are matched with yours.
If not, look for (I presume) compression drivers, with the correct sensitivity (sound output at 1 watt) to your woofers. You may need to purchase an adaptor to make the new ones fit the horn.
Also, try to match impedance - if the old ones were 8 ohm, look for new ones that are 8 ohm. Use something different, and the crossover point won't be what's intended. It will either come in an octave too low (the tweeter would die) or too high (big hole in the frequency response).
Jan 14, 2010 | Motorola Audio Players & Recorders
Want to bridge 2 channel amp to push single 4 ohm dvc sub
Hello k_rabbit89,
A 4 ohm DVC sub can be wired in series like you described for an 8 ohm load or the voice coils can be wired in parallel for a 2 ohm load.
If your 2-channel amp isn't stable down to 2 ohms when the channels are bridged (most 2-channel amps are only stable to 4 ohms when bridged), you do not want the voice coils paralleled. The amp will overheat, go into protection mode, and eventually fail completely. A sub with 2 ohm voice coils would be a better fit. That way, you could series the coils for a 4 ohm load and the amp would operate OK with the channels bridged into that load.
But anyway, for the best power from THAT amp to THAT sub, your best wiring solution would be to wire each voice coil to a separate channel. The problem with that is that the signal to each coil needs to be EXACTLY the same or you will have one coil trying to move the cone out while the other one tries to move it in. You can closely approximate identical signals on the output side by using the same input to both channels. Do this by using only one RCA connection (either right or left channel) from your head unit and split it with a "Y" cable.
Hope this helps.
Sep 12, 2009 | Car Audio & Video
Ohm calculations; 4 and 8 ohm sub woofer?
+ output from amp to + input of 4 ohm to + input of 8 ohm AND - output from amp to - input of 4 ohm to - input of 8 ohm is a parallel circuit = 2.66 ohm impedance load for amp
+ output from amp to + on 4 ohm - on 4 ohm to + on 8 ohm - on 8 ohm to - of power amp is a series circuit = 12 ohm impedance load for amp. Clear as mud??
Clear as mud?
Jun 11, 2009 | Jl Audio 12W0 Car Speaker
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Car speakers
I take it that you are running it off a factory head unit and your not getting enough drive on the new speakers. Are the new speakers a component splits? Does it come with a separate tweeters and crossover? If so... are the new speakers 4 Ohm Impedance? Coz the only thing i could think of is that these new speakers you have must have a higher impedance than that of the previous drivers. the higher the impedance the less sensitive. Your can try to match speakers impedance usually head unit is at 4 Ohm. Please let me know how you went. Cheers
Jun 02, 2007 | Image Dynamics NX30 Car Tweeter
205 people viewed this question
 Grubhead
Grubhead
