Question about Refrigerators
Fisher and Paykel N308 upright freezer. It has slowely been defrosting from the top shelf.. we are now down the the last two shelves. I can hear a fan working on the inside. Ive pulled it out and vacuumed the parts I can see at the back. There is a large black round container that is very hot. There was a very small amount of frost build up in the freezer itself on the back wall. This has been removed. The door seals appear to be fine and are clean. The shelves are shutting properly. We have had several accidental episodes of the door being left open and things defrosting slightly. Last time was about 6mths ago. The unit is about 10-15years old.. any ideas?
  • delia328 Jul 16, 2010
    Thanks so much for this! so im wondering if this sounds like an expensive fix .. if its worth doing or not? I do know that a technician call out is $99 and a regas is $500!
  • Robyn Murphy Jun 21, 2018
    Is the N308 F+P upright frost free?
  • 4,070 Answers
If your shelves are the evaporator and only the bottom two are covered by frost then you probably have a freon leak and it is now low on freon. This condition requires a qualified tech to service.
Or if you have ice built up on the evaporator coils behind the rear cover inside the freezer. The ice on the back you found is probably just the tip of the iceberg do to speak. The times the door was opened would add to the amount of ice buildup. This would indicate a defrost problem. The info below mentions the fridge but also applies to a freezer if it has an auto defrost system.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jul 16, 2010
  • Charles T Nevin
    Charles T Nevin Jul 16, 2010
    Because of it's age if it requires a tech and repair for a leak and recharging the freon it may not be worth fixing since it would cost several hundred dollars. You may can get an estimate from someone before you call them out.
    If the sealed system is not the problem then the other items are not very expensive and should be worth it to fix.
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
The top shelf in my upright freezer ices up badly; but the rest of the freezer is great - no ice! What causes this and is there something I can put on that shelf to keep the ice from building up.
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought.
Sep 02, 2009 | Freezers
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Not all the shelves are getting cold
All the shelfs should be getting cold starting at the top and working down. It may have a leak in the system or a restiction not letting the freon flow. It could of had the problem before the defrost. Small enough problem to stay frozen but won't bring back down to temp. Check to see if it's still in a sealed system warranty if so call for service.
Apr 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fisher and paykel vertical freezer N308 model
bec,
Sounds like you are freezing up! The coils are so frost-laden that they will not allow the unit to function. The unit will need a complete defrost. I'm not familiar with the exact layout of this unit but I can tell you that it needs to be shut down, have warm air blown into the fan area and completely freed of ice. If you just leave it open and turned off, this takes about 2 days.
Possible causes: humidity in the air is condensing...very humid area, too much 'window shopping', not closing the door completely, possible damaged door gasket.
Others: (on older units)
Possible defrost timer problem...or low gas. Try the defrost route. We'll go from there.
Dec 03, 2007 | Freezers
Refrigerators Logo
1,508 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
