Question about Dryers
Kenmore 86980100 dryer no heat
  • randy_go_blu Mar 12, 2009
    I also have a 10 year old Kenmore 90 series electric dryer (Model No. 67902790). I have had it in for service twice in the past 2 years. Both times, the dryer would run, but would not heat. Both times the repair company replaced the thermal cut-off. This last time I decided to replace the thermal cut-off and the hi-limit thermostat myself. I just finished installing them, but still no heat... I removed the heating element, inspected it and tested for continuity. Although it looks pretty well used, it tested fine. Now i am wondering if I may have installed the cut-off and/or hi-limit thermostat incorrectly??? Or, is there some other potential issue??? I disconnected the leads from the heating element, turned on the dryer and tested the voltage at the leads only to find that it is not getting any juice. What is my next step??? If no suggestions, my next step is going to be putting it on the curb!!!
    Novelist:
  • 184 Answers
NO HEAT, CHECK THE FOLLOWING:
1. CHECK SETTINGS OF THE SELECTOR SWITCH. MAKE SURE A HEAT SETTING HAS BEEN SELECTED.
2. IF IT IS AN ELECTRIC DRYER, CHECK FOR 240VOLTS AT THE OUTLET.
3. CHECK THE HEATING ELEMENT FOR 240 VOLTS AT THE TERMINALS OF THE ELEMENT WHILE THE DRYER IS RUNNING. IF NO 240 VOLTS, TRACE WIRING BACK TO OTHER COMPONENTS OF THE HEAT CIRCUIT. WHEN YOU FIND 240 VOLTS ACROSS THAT COMPONENT, THAT IS THE BAD ITEM.
4. CHECK FOR BURNT WIRES IN THE HEAT CIRCUIT. (HEATER, THERMOSTAT, HIGH LIMIT THERMO, MOTOR CENTRIFUGAL SWITCH, TIMER, THERMAL FUSE).
Posted on Apr 22, 2008
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer model 110serial #86980100 will heat like it used to
The fuse mounts on the blower assembly in the back under the dust cover.3c90523.jpg
Posted on Feb 02, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Kenmore 70's dryer, not heating,
Maybe timer, try a different heat cycle.
Feb 06, 2010 | Kenmore Dryers
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer runs but does not get hot
I have the same dryer and I forgot what the part was called, i believe it is the heater element which you need to replace. That is what I did and it fixed the problem. very easy to install
Feb 15, 2009 | Kenmore 63942 Dryer
Kenmore dryer model 110serial #86980100 will heat like it used to
Feb 02, 2009 | Kenmore 62602 Electric Dryer
I am trying tochange my
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similar with one exception. The 4-wire plug uses an additional (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope this helps you.
Feb 29, 2008 | Dryers
Dryers Logo
1,171 people viewed this question
Top Dryers Experts
