I have a studiomaster proline 1648 gold mixer, when i input stereo out from my pc into 2 channels. the out put is 2 xlr to amplifier speaker. but the sound is only one side (either left or right). i have tested both speakers and cable do not have problem. please advise
    Guru:
  • 256 Answers
Pleas check which side of the cable does give you sound. Lets say the red RCA line works with the right speaker. Now swap the wires at the back of your mixer ie. change the red plug to the white input on your mixer. If no sound comes through, your mixer might be dead on that channel.
Posted on Jul 16, 2010
How to connect boss dd3 with studiomaster 16 channel mixer?
Use 1/4" plug cables or XLR-1/4" cables with the fx loop, depending on the type of connector of your mixer. Don't use batteries, they don't last. Use a type 2 (for noise reduction) 9V wall outlet adapter.
Apr 29, 2017 | Boss Music
How to connect a samson s mix 5 channel mixer
It depends on what you are trying to connect. The XLR would be a professional type microphone, it does not have phantom so a condenser mic will not work. The other inputs should match your stereo equipment. The output goes to your amp.
The Samson S-Mix is a miniature, rugged 5-channel audio mixer with 4-line inputs and a single XLR microphone input. The line inputs are comprised of two 1/4" phone and stereo RCA phono connections. Each input channel has a rotary volume control and the outputs include stereo RCA phono connectors and 1/4" TRS phone headphone output. The S-Mix is powered with an 18 volt AC adapter.
Mar 28, 2014 | Samson S-Mix Miniature Audio Mixer
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
When I hook up my ipod to the speaker, its not loud
The IPOD does not put out the line level and worse, the IPOD is stereo so you need a mixer to mix the L and R channels before sending them to the line level input of the DSR112. Shorting the L and R from the IPOD together as can be done with commonly available adapters gives poor results. The input of the speaker is a balanced input and needs to be XLR or TRS BALANCED input. A 1/8 inch stereo jack to 1/4 inch adapter results in the two channels of the IPOD subtracting and very low signal that is corrupt. Do the job right and use a small mixer to combine the L and R of the IPOD.
Jun 09, 2011 | Yamaha DSR112 Powered PA Speaker (1300...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Connect active subwoofer to Studiomaster Walkabout
You CANNOT have a stereo set of RCA jacks "wyed" into a single XLR mono input.
The RCA output drivers will "fight" each other. Some things will appear to work, but give poor performance.
You could make a rudimentary passive mixer by putting a series resistor say 1K ohms from each of the RCA's to a common UNBALANCED input of a subwoofer.
The XLR is balanced so that would not really work unless you also have an unbalanced input on the subwoofer.
The right way to do this is to get a cheap two input mixer that has EQ with it and mix your two mains before sending to the subwoofer. You want a little mixer that also has balanced outputs (XLR or TRS) to send to the subwoofer.
UNLESS the subwoofer has EQ in it, you really need to have an EQ in the little mixer so that you don't send high's to the subwoofer... They don't like highs and the sound will suffer.
Feb 01, 2010 | Music
How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Dec 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Signal Light Problems Yamaha P2500
Stereo amplifier = two channel..A and B.
1. Make sure that your stereo audio mixer has an output from LEFT going to amp channel A and output RIGHT going to channel B.
2. Check that the "Pan" control on your audio mixer is set to the 12:00 position.
3. Inputs to mixer...make sure the music/microphone input channels "Pan" controls are also set for 12:00 as well.
Jun 11, 2009 | Yamaha P-2500 Amplifier
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
253 people viewed this question
 Grubhead
Grubhead
