Question about BenQ Joybook 5100U Notebook
My laptop (hp Pavilion dv6000)touchpad scroll is not working. Neither does the Synaptics Pointing Device icon in the tray displays any footprint as I use the touchpad
  • 54 Answers
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Posted on Mar 14, 2009
  • 7 Answers
SOURCE: inoperative touchpad scroll zone
rwertheim,
I have a MX8711.
I assume you are running Vista.
After you have updated your virus protector program and run a complete scan. You "could" be fixing it and if it is a virus problem, it is immediately reinfecting the driver. If it still doesn't work, I recommend you:
1. Rollback the driver of your touchpad. If it was working, this might do the trick. You can do this at Control Panel > Mouse > Hardware (tab) > Properties (button) > Driver (tab). If it has been updated and that caused the problem, you probably can "Roll Back" to the previous driver and that option will be highlighted.
2. If not, then your driver is probably corrupted. Go to Gateway Support and download the touchpad application file for your computer and SAVE IT TO YOU DESKTOP AND DO NOT RUN IT. Replacing only the driver usually doesn't work in these cases but try that first. Go to Control Panel > System > Device Manager > click on the (+) sign by mice and dbl click on the Symantics PS/2 Port Touchpad (or what ever yours is) > Driver (tab) > Uninstall. When you restart, it should reload the driver from the application that is still installed.
3. If that dosn't work, I recommend uninstall the application from Control Panel > Programs & Features. Restart your computer and install the application you saved on your desktop.
I hope this helps.
Have a blessed day.
Tracker Tom
Posted on Jun 06, 2008
  • 16 Answers
SOURCE: Scroll function on my Toshiba Satellite TouchPad isn't working
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
Posted on Feb 14, 2009
  • 630 Answers
SOURCE: i recently bought an hp pavilion dv7 laptop. the
Check the settings in Control Panel>Mouse you may need to turn the feature on
Posted on Jul 02, 2009
leecom72
  • 4806 Answers
SOURCE: Touchpad does not function
It sounds to me like the touchpad drivers are corrupt and need reinstalling.
Go here to Toshiba support, download and install the touchpad drivers and utility and see if that helps.>>>>>>
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1845344&rpn=PSL48U&modelFilter=L45-S7419&selCategory=3&selFamily=1073768663
Good luck and please post back if you need anymore help or advice.
Regards.
Posted on Aug 17, 2009
Testimonial: "Thanks a lot!! It worked. "
Synaptics ps/2 touchpad not working after i installed new gamer mouse
It is possible that the install of the gamer mouse deactivated the synaptics touchpad. you can click on the icon in the system tray of the touchpad, browse to settings. There you should find a place where it asks if you want the touchpad deactivate when another pointing device is connected. Deactivate the checkbox and you should have your touchpad back on.
Aug 07, 2012 | Gateway Computers & Internet
My touch pad won't move the page up or down
First, look for an icon called "Synaptics Pointing Device" in the taskbar on the bottom right of your desktop. If it is there, right click it and go to options. From there, there should be an option for "Gestures" which will have an option to allow you to reenable scroll.
If you don't see that icon, you can try going to "Start">"Control Panel">"Mouse" and finding the option there.
If none of that seems to work, go to HP's support site, look up your model number, and download the associated Touchpad Driver.
Aug 24, 2011 | HP Pavilion dv7-1132nr Notebook PC
I would like to turn off the TouchPad while I'm using an external mouse. What are the commands for that action?
two options:
first: go to system tray, locate the Synaptics icon, right click it and left click open. then go to device settings then click "settings" and locate on the left "virtual scrolling". UNCHECK "enable virtual scrolling". Click apply and ok.
second: click START, then CONTROL PANEL, then DEVICE MANAGER, then MICE AND OTHER POINTING DEVICES, then right click on PS/2 COMPATIBLE, the left click on DISABLE, click apply and close
Jul 26, 2011 | HEWLETT-PACKARD HP G71075DX Pavilion...
Problem with the HP G60-235DX PC Notebook Notebook Touchpad won't scroll. (Synaptics) Previously it would scroll with no problem, then suddenly quit. How do I restore the function? Previous...
Have you checked the settings of your synaptics? Usually there's an Icon on the taskbar for synaptics you can right click it and check if "disable touchpad if usb pointing device is present" is checked, if so uncheck it then your touch pad should work again.
Here's a link for a step by step instruction though this is for windows xp but steps are the same. Hope this works for you:
http://blueboxagency.com/helpdesk/?page_id=16
Apr 10, 2011 | HP G60-235DX Notebook
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
The touch pad its not working properly on my hp pavilion dv7
my buddy brought his to me last week with this problem he could move the curser but had to hit the button to left click when he tap on the pad it did nothing you may have changed the configuration in Synaptics Touchpad you may have diabled certain settings in it i usuallu has a icon to the bottom right near clock it should be a red symbol it might say Synaptics pointing device when you but cursor over it
Sep 02, 2010 | HP Pavilion dv7-1240us Notebook
Touchpad scroll not working, I hv recently installed windows 7 a few days ago. It was working till today.
mostly AMD inside models comes with Synaptics Touchpads
download this & install it
after restarting your PC check if it works...
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44995.exe
otherwise Uninstall Synaptics Touchpad Driver
try this
Intel inside models comes with ALPS Pointing Device
ftp://ftp.hp.com/pub/softpaq/sp45501-46000/sp45558.exe
Mar 02, 2010 | HP Pavilion dv4z Notebook
I downloaded the synaptic mouse touchpad driver - and can no longer scroll up or down the screen without holding down the left click button. please help
Right Click the Synaptics Pointing Device Icon on your Task bar tray, click POINTING DEVICE PROPERTIES,it will open the Mouse Settings, Click the Wheel Tab and make changes as you want it
Thanks
Oct 25, 2009 | HP Compaq nc6220 Notebook
Touch pad scrolling problem
Mar 14, 2009 | HP Pavilion dv4000 Notebook
TOUCHPAD
go to control panel = mouse pointer = look for the pointing device, maybe its called synaptics pointing device on you too then you can unchecked the buttons and even the whole device itself from it.
Feb 05, 2009 | HP Pavilion dv6000z Notebook
BenQ Joybook 5100U Notebook Logo
686 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
