Question about HP Photosmart 635 Digital Camera
Camera only dowloads half the pictures on memory card
Hi
I have an HP Photosmart E427. When we try and downloaded the images off the digital card to the computer it only downloads some of them. The rest of the images say 'downloading' but there is an X where the image should be - we are using microsoft scanner and camera to do this. The pics are visible while the memory card is in the camera.
This is the second memory card we have that started doing this after awhile. Any suggestions?
  • 121 Answers
I know some of my cameras have a 'on board memory' and chip. Most likly the desired pictures are there, or the memory card conection (in the camera) is not making a full connection. can you clean the contacts?
Posted on Apr 21, 2008
  • Timothy Brooks
    Timothy Brooks Apr 22, 2008
    Hi. personally I have used a dental probe (needle) to reposition the contacts with good luck, but please be careful, the contacts are quite delicate.
The card on my Photosmart HP E427 appears to be locked all of the sudden. I get a message that says "cards is locked" - What caused this and how do I unlock the card?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 17, 2009 | HP PhotoSmart M437 Digital Camera
Cannot delete images in the camera.
Check the card and see that the little slide switch on the side is moved to the unlock or clear position. You try to delete images off another card to see if it is the camera that is defective. Is it still under warranty?
Jan 20, 2009 | HP Photosmart 320 Digital Camera
What to do, I forgot to put memory card in HP R707?
Hi
Do you want the pictures transferred to your memory card? that depends on the option available on the camera, try inserting the memory card. select a picture then check options if you can move it to a memory card. if not, download it to a computer and transfer it to the memory card folder.
Hope this help
Jan 11, 2009 | HP Photosmart R707 Digital Camera
Cannot download pictures from camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 28, 2008 | HP Photosmart 635 Digital Camera
Hp photosmart m415 digital camera
You can do that. In the camera setup menu scroll down to the last option "move images to card"
Apr 06, 2008 | HP Photosmart M415 Digital Camera
How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
Photosmart E327 digital camera
I had to buy the memory card for mine when I got it and it holds about 160 images.
Feb 16, 2008 | HP Photosmart E327 Digital Camera
Error Saving Image
From HP's website:
Check this document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00191836&lc=en&cc=us&dlc=&product=410648
Error saving image or Error saving video. The optional memory card that is installed was removed before the camera finished writing to the card or was half-locked.
  • Always wait until the Memory light stops blinking before removing the memory card from the camera.
  • With the camera turned off, remove the memory card and check to see if the locking tab on the edge of the card is fully in the unlocked position.
Also, check this link:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=br&lc=en&docname=c00017052
You might just have to reformat your memory card.
Mike
Nov 12, 2007 | HP Photosmart M517 Digital Camera
Memory card problem
use batteries with higher mah value prefereably above 2000 mah .use energizer or duracell
Sep 17, 2007 | HP E427 Digital Camera
HP Photosmart 735 "unsupported image file"
You might want to try a different memory card.
Jan 21, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart 635 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
