Question about Vatical Entertainment Seadoo Hydrocross 2001 for Nintendo 64
1996 seadoo jetski leaking oil
My brother changed gas tank and now the mixing oil is leaking inside hull. It's not the oil tank. Could he have hook up one of the sending unit 4 hose's wrong ? could this cause oil to blow out somewhere if hose's are not hook up right?
  • khartley410 Jul 16, 2010
    yes
    There is a reserve built in the gas tank, so I'm not sure of the way the hose's are connected?
  • 11,896 Answers
Two **** air in, Two blow it out. the hose to **** oil is likely blowing it.
Posted on Jul 16, 2010
    Thanks Can you tell me how to check out what hose goes where?
  • Nate Stansfield
    Nate Stansfield Jul 16, 2010
    You can download the repair manual here with diagrams
    http://www.mediafire.com/?hymbvb1thim
I have a 1995 Toyota corolla and I recently noticed I had a gas leak I sealed the hole with JBL epoxy to hold me over until my new tank arrives but it looks as if there is oil mixed in with the gas .
Keep checking the oil level and the transmission fluid level to make sure they stay full, but there should be no oil in the gas tank.
There may be water, however, and it may be brown like oil.
Water will sit in the bottom of the tank and make rust underneath the gasoline, since gasoline floats on water.
Dec 29, 2016 | 1995 Toyota Corolla
Got a 1996 polaris xplorer 4x4 .wont start,fan and oil light is on,we mix gas in the tank,oil jug empty,could this be why oil jug empty.
if it has a oil light on and the oil reservoir is empty , the it would be reasonable assumption that unless there is oil available to mix with the fuel , it will not be allowed to start
It is a 2 stroke that has a metered amount of oil that varies according to engine rpms and is not a pre-mix situation that you have assumed it to be
so fill the oil tank with the correct 2 stroke oil, remove the oil mix fuel and save it for a whipper snipper or other small engine , fill the tank with the correct fuel and it will most likely start
Jun 11, 2016 | ATVs
1998 kawaski 900 stx jetski hull fills with water after 20minutes of riding
stick it in the slipway on the trailer and keep it strapped down securely , run engine up and down the rev range with seat off and see what leaks !!
Apr 18, 2015 | Motorcycles
Ts 510 has a oil tank along with gas tank. Why?
to oil the chain of course .all of them have the oil tank even electrics
Mar 09, 2015 | Garden
Steelcraft generator 3300 watt Gas tank shut off
The floater of the carburator is bad(Needle). its leaking gas at the carburator and the gas is coming inside the engine at piston intake valves.
Replace carburator needle that stops the intake of gas at the Carburator.
Sep 02, 2014 | Electrical Supplies
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
Jun 24, 2012 | Boating
My 1996 Seadoo xp, one of the carb's flaps is
either run it and spray carb cleaner into it (idled up a little) or start adding good in tank cleaner to fuel.
Jul 09, 2011 | Boating
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Dunno where to put oil
Make your life easy. Call your local Jetski dealer and ask where the oil tank is located. The oil needed is called TWO STROKE ENGINE OIL. Buy the oil from the dealer as a thank you for their help. P.S., wait 30 days and you won't freeze so bad.
Mar 16, 2009 | 1996 kawasaki ZZR 1100
Vatical Entertainment Seadoo Hydrocross 2001 for Nintendo 64 Logo
158 people viewed this question
Top Vatical Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a Vatical Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
