I have a problem I have my ps3 hooked up to my lg flatron W1942S monitor and i have 2 problems. It is a wii/ps3 vga cable I have the picture however distance wise in game play shows a white foggy haze and my color's no matter what setting I try shows my colors brighter than they are. As well it clicks on and off like for 1-2secs ramdomly which I thought maybe was a sleep mode problem. I have looked up the manual for this monitor and it says is clicks on and off check interlace option what the *** is that and how so I turn off sleep mode not shown in manual.
SOURCE: problem displaying nintendo wii graphics
After more checking around I found out this is not an uncommon problem with the wii. Apparently there is a design flaw that causes the graphics card to overheat, which creates various types of distortion. It may have something to do with using wiiconnect24. I am sending my wii back to nintendo for repairs.
Posted on Apr 12, 2008
SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
Posted on May 03, 2008
  • 62 Answers
SOURCE: my lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Posted on Dec 20, 2008
tomhar
  • 20 Answers
SOURCE: How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Posted on Mar 08, 2009
SOURCE: LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Posted on Apr 19, 2009
Lg 29" monitor vga setting won't go to 1920 x 1080
If it was fine then you did something like changed connectors, cables, video card. VGA will not do that high a resolution.
Mar 30, 2014 | LG Flatron W2242TQ-BF 22" LCD Monitor -...
Vga cable problem
Step 1:
vga cable 9 wirs corict conniction
Step 2:
i need schematic digram of vga cable of lg t730sh
Nov 26, 2012 | LG Flatron 775FT 17" CRT Monitor
I need to open the back cover of lg flatron w1942s
Here is a youtube link that has many video repair guide for monitors, all monitors open basically the same way so just watch one and get the general idea for your unit.
https://www.youtube.com/user/cclla1?feature=mhee
Nov 16, 2012 | LG L1730SF 17" LCD Monitor
Dual Monitors - why does my second monitor have bad picture?
As long as something isnt broken, using the HDMI and the D-Sub should be fine. From your fuzzy pictures I suggest that you want to double-check your cables.
Have you tried to switch it? If you put the second monitor on the D-SUB and the picture is still faulty, its very likely the problem is your monitor.
Dec 29, 2011 | LG 22" FLATRON LCD Monitor
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
There are two vertical lines on my lg flatron w1942s monitor one is red and other is green line
Go to the buttons on the bottom of your monitor it will give you an option to change the vertical and horizontal setting.
Mar 12, 2011 | LG W1942S 19" LCD Monitor
Pleae help me out to set English language for my monitor (LG FLATRON W1942S). Also guide how to find the online user manual.
The manual for the W1942T is here, and it should be close enough to the W1942S to help you. The 1942S is listed on LG's UK site, but there is no manual available.
Feb 06, 2011 | LG W1941S-PF Monitor
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
Screen stays in analog mode
analog usually means its hooked up via VGA cable
digital means its hooked up via DVI cable
Sep 04, 2009 | LG Flatron L1750S 17" LCD Monitor
I have a yellow haze overall. Color distorted not very clear.
Some reasons for the above problem......
1. Faulty connectors and cable
2. Faulty Picture tube (in case of CRT)
3. Faulty components in monitor's picture tube base circuit board
The same problem will happen when the display section of mothrboard got any complaint
Try these....
1. Try with a new CPU or Monitor and ensure the problem that with Monitor or not
2. If the problem with monitor, try changing the VGA cable
Mar 02, 2009 | LG Flatron F700P 17" CRT Monitor
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
