Question about Nordic Track NordicTrack T9 ci Treadmill
The digital touch screen display is not showing up. The screen is illuminated but no words are showing. I just purchased this treadmill and have used it twice. It's brand new! Any suggestions? The fan options and sounds work and I can adjusts the speed and incline with the other buttons but the digital display functions aren't showing up, even when I insert the ifit card.
  • 4 Answers
What your seeing is a common problem which I encountered on 3 separate displays. I have since diagnosed the problem and am currently life-testing a working solution. The real problem is very poor design of the negative voltage generator circuit for the display contrast. Everything else is working fine except that circuit. I have designed and installed in my treadmill a replacement circuit that is much stronger and am currently testing it. zubatcha@gmail.com for more information
Posted on Nov 01, 2010
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
The console display is bad and needs replaced
Posted on Aug 11, 2010
  • zubatch Nov 01, 2010
How can I fix the screen on my Lumix DMC-FX30 which does not illuminate?
First, check the display settings.
Next, the camera usually switches back to its default when the shutter release is touched. Check those settings, too.
Aug 20, 2014 | Panasonic Lumix DMC-FX30 Digital Camera
Power on screen shows safe
Reset the treadmills. and proceed again. God bless you
adjust the REED switch, clean it, test for open or faulty, tight the connector very well. see the diagram.
Jun 16, 2013 | Exercise & Fitness
Treadmill touch screen display turns on then off
you may need a new display overlay. What is the make and model?
Jul 09, 2012 | Proform Power 1080 - Treadmills
Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
display console or wax/lift
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Life Fitness 9100 Next Generation...
Heart rate shows up on screen even though not touching sensors. When heart rate is displayed cannot access anything else on screen
proper grounding the machine mite help. the frames are powder coated and they dont remove enough paint for a good ground point chek and make better contactwith frame
Feb 27, 2011 | Nordic Track NordicTrack Elite 9500 PRO...
Treadmill automatically speeds up upon start up
If you have a unit where the speed can be adjusted with 1 mph increments 0 to 10 and with speed up or down .1 mph increments . it sound like the key pad itself is causing this problem. Depending on manufacturer you can purchase the keypad/overlay and some will want you to purchase the entire display.
Mar 01, 2010 | Proform Exercise & Fitness
Is the display intended to be illuminated or is it to be read 'in the dark' so to speak? As it is digital, and as the model in the store appeared to be illuminated, I don't understand why I cannot view the...
You should be able to just touch the thermostat and it should lite up to see the numbers. If it does not lite up you have abad stat. Working but no display lite. But just try touching the screen if it is touch type stat or just hit the up or down bitton qucikly and see if it lites up. Please leave feedback Rus
Dec 07, 2009 | Honeywell Programmable Thermostat Heater
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Jun 05, 2009 | Exercise & Fitness
Digital screen reading different than actual speed
unplug it for about a half hour and if it has an internal battery remove it at the same time.... that should reset it back to factory settings
Mar 22, 2009 | Icon Treadmill
Fuji pix E510
Do a Google search with the following string:
(Brand Name) (Model Number) "display screen"
This should bring up sites where this can be purchased (if Flash is a separate item - change the words "display screen" for flash.
Good luck.
Apr 24, 2008 | Fuji FinePix E510 Digital Camera
Nordic Track NordicTrack T9 ci Treadmill Logo
913 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
