Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Oven will not heat up temperature doesn't go past
Oven will not heat up temperature doesn't go past 100
    President:
  • 1,891 Answers
Replace the oven sensor . if this does not correct . look at the ELECTRONIC OVEN CONTROL. THE SENSOR TELLS THE CLOCK THE TEMPT AND THE EOC CONTROLS OVEN TEMPT . . now don't forget to ck the element first and the 220 power . .. if i/2 of the power is missiing due to a triped fuse the low tempt or not temp is possible.. mm
Posted on Jul 16, 2010
2 Suggested Answers
garing
  • 998 Answers
SOURCE: Oven heats, but does not get to correct
when you first turn it on both elements should come on(your top element may be burned out)if so turn breakers off just take out the screws on the mounting plate pull out and take wires off and replace
Posted on Aug 25, 2009
Oven 388-610 won't heat up past 100F.
Hello. I'm not familiar with your particular unit but if it operates like most other brands, the display doesn't show temps under 100 degrees. From what you're describing, the oven isn't heating at all. I would suspect either a defective bake element or, an open thermostat which cuts the electricity to the elements if the temperature gets too high. If the safety thermostat checks good, then the problem most likely is the main oven control board--which simply activates a relay to turn on the element.
Nov 06, 2015 | Gaggenau Ovens
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
How do you reset the frigidaire wall oven?
Good Afternoon Friend,
I understand you are trying to reset your Frigidaire wall oven, model# FEB27S5A, due to it not heating above 100 degrees. I suggest resetting at your homes circuit breaker for 3-5 minutes. When you restore power, you will first need to set the clock. After setting the clock, preheat your oven. If you are still noticing that the temperatures are still not going above 100 degrees, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to not reach the desired temperatures. Hope this is helpful.
-Best regards-
WP
May 11, 2014 | Frigidaire FEB27S5A Electric Single Oven
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
The temperature markings on the top oven/grill have worn off - can anyone help
the first knob has tree positions in the middle is off to the left the top (grill) heats to the right top (grill) and bottom heat, the second knob indicates the temperature in the following way ..50....100....150....200....250..good luck
Nov 27, 2012 | New World E70DOa Electric Double Oven
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
Teperature i snot rising above 100, why?
Assuming your Thermador is electric, and it is only warming up a little, this is usually one of three things:
1. Heating element - with oven power disconnected, check that the elements resistance is in spec. Usually around 20 ohms.
2. Thermistor - this senses the temperature of the oven. Again, check the resistance. Depending on your model, it should be around 1050ohms at room temperature.
3. Electronic Control Board. These can be rebuilt quickly and reliably at www.fixyourboard.com. Some are still available to buy online.
Hope that helps
May 21, 2010 | Thermador SMW272 Electric Double Oven
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
Aug 10, 2009 | Belling XOU270 / XOU271 Electric Single...
Oven doesn't heat up to desired temperatures, and if it does, it doesn't maintain that level
replace the thermostat temperature probe inside the oven, that is the cause of this problem alamost 100% of the time
Jun 27, 2009 | Ovens
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
303 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
