I need replacement foam earpads for my Koss TNT/77 headphones. They crumbled apart over time.
mastersaintx
  • 928 Answers
SOURCE: Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
Posted on Nov 26, 2008
  • 87 Answers
SOURCE: Replacement foam for Beyerdynamic DT 531 Consumer Headphones
Same issue with mine, unfortunately this is par for the course with petroleum based foams. Fortunately, the headphones themselves are pretty easy to take apart. Slip a small flat screwdriver in the crease between the plastic casing and the black rim that holds the blue/gray velvet ear pad. The entire pad assembly pops right off and then you remove the old foam disc from inside. Once you have them apart, you can replace the foam with more thin foam obtained from ebay or wherever, or some other soft material. FYI, BeyerDynamic's customer service is actually pretty good if you call them on the phone. My cat chewed through my cord a few years ago, I was able to call them up and order an OEM replacement. It cost me about 8 bucks, I was able to solder it up and it worked just fine. MY problem is that the foam padding INSIDE the velvet rings is losing its pliability. I've removed the rings and washed them a couple times (they do get pretty filthy). I will probably make a couple small incisions in the back of the material itself (hidden inside the set itself when together) and restuff with some cotton batting.
Posted on Jun 11, 2009
SOURCE: Need replacement earpads for Sony FM/AM Walkman SRF-H4 headset radio
LIKE YOU ALL, NO CURE OR REPLACEMENT FOR THE ROTTED PADS. WENT TO HOME DEPOT AND BOUGHT ECONOMY PLUS BRAND AIR CONDITIONER FILTER MATERIAL, ABOUT $3.00, FOR A WALL AC. THEN WENT TO DOLLAR GENERAL AND BOUGHT SCUNCI BRAND BLACK HAIR ELASTICS, EIGHT OF THEM FOR $2.00 TO KEEP PONYTAILS, NOW EAR PADS, IN PLACE. CUT THE AC MATERIAL TO FIT, AND ATTACHED WITH HAIR ELASTICS. ONLY A PURIST WOULD COMPLAIN ABOUT LACK OF COLOR MATCH. THERE WAS A SOLUTION, ONLY A MATTER OF FINDING IT. GOOD LUCK ALL OF YOU. R J BURNS, PENSACOLA, FL
Posted on Sep 09, 2009
SOURCE: i've noticed that replacement inner
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
Posted on Dec 22, 2010
Grubhead
  • 5259 Answers
SOURCE: need new earpads for my
See my tip on dealing with dodgy cables/plugs on headphones. There's a website that sells them at the bottom of it. Just click my user name to find it.
Posted on Feb 08, 2011
Where can I order replacement ear pads for Brookstone model #431064 Foldable Noise Cancellation Headphones, last stocked by them in 2003? Vinyl pads' finish is crumbling, but still soft.
You might be best just searching e-bay for headphone earpads. Then looking out for something that looks like yours. Most of these none standard headphone companies will tend to be made by other companies such as JVC or Sony. So just search for what they are, not who makes them.
Jun 08, 2017 | Brookstone Audio Players & Recorders
There's something loose in my left cup and it's really obnoxious if I move my head just a little... How do I take apart the headphones to I can fix this and still put them back together?
Most headphones open by removing the earpad and any foam. You should see access screws then. You might have to tear the foam off. You can glue it back with Bostik white glue afterwards.
Nov 04, 2010 | Sony MDR-XD200 Consumer Headphones
Fabric ear covers failing on my Koss headphones.
Try their limited lifetime warranty for resolution:
http://koss.com/koss/kossweb.nsf/warrrepair5?openform
Apr 21, 2010 | Koss UR-30 Professional Headphones
Product KOSS UR15C headhones. Problem: short in the cable which causes sound cutout when moved. Its right at the connection to the earphone. WHAT I NEED TO KNOW: How to take the earphone apart...
I'm afraid there's is no easy way of doing it, most headphones I have fixed needed force to get the pads of and for that matter to put them back on! It's just a case of taking great care and easing it off a bit at a time. If you encounter any foam that can be glued on afterwards with Bostik solvent free all purpose glue.
Apr 03, 2010 | Koss (141283) Consumer Headphones
Foam gone on both can you help me need four total koss m80
I have ordered headphone foam from Koss myself and they were very reasonable (under $6 delivered) and fast.
This is from Koss website.
http://koss.com/koss/kossweb.nsf/csfaq?OpenForm&Start=1&Count=30&Expand=2&Seq=3
"In most cases, if we have the parts still available, we can repair your old Koss product. Please call us at 1-800-USA-KOSS and talk to a customer service representative for part availability and pricing."
Feb 04, 2010 | Audio Players & Recorders
I need new ear pads for my Aiwa HP-CN5 headphones.Is there a source for these?
I hunted around. No luck. Then I stopped in an found the perfect fit from of all places Radio Shack. The Earpads come with a smaller pair and you have to buy both but they are an excellent replacement. The Radio Shack replacements are #330-0288 - Replacement Headphone Earpads - $6.99 USD.
Oct 26, 2009 | Aiwa HP-CN5 Headphones
Wire loose
If you can carefully take the foam earpad off you might find screws holding the speaker plate to the cup.
May 11, 2009 | Altec Lansing AHP712i Consumer Headphones
I have the same problem with a pair of Fostex Headphones. I have taken them apart and I have removed the rubber type ring that the foam fits over.
I am going to order a cheap pair of thin foam Headphone ear covers from Ebay. (They are available in various sizes) and stick the foam to the ring and follow that
by sticking the ring back in. Should work if the foam is thin enough. What do you think?
Eddie
Nov 27, 2008 | Beyerdynamic DT 531 Consumer Headphones
Koss Pro-4AA
Don't bother, Koss has a lifetime replacement policy on some headphones like the Pro-4's. All you pay is shipping. Call the repair department.
Feb 25, 2008 | Koss PRO-4AA Consumer Headphones
135 people viewed this question
 Grubhead
Grubhead
