Question about Dometic RM2852 Refrigerator
Wiil not cool
My rv fridge will not get cold at all---the heater is getting hot but no cooling in the fridge.The indicator is not showing any faults. I have tried it on Electric and Gas.
    Champion:
    Scholar:
  • 210 Answers
If the heater is geting hot and not cooling sounds like it is in the defrost mode just defrosting or stuck in defrost mode.If it is in defrost mode it should stop defrosting after a while and start cooling. They defrost every so many hours depending on how they are set.
Posted on Jul 16, 2010
The outside of my refridgerator is hot and the food is getting hot to. It is a Maytag.
Are you sure it is a refrigerator and not an oven?
The outside generally warms up while the compressor is working - or at least the area where the condenser is. If the cooling circuit isn't working then the outside doesn't get warm and the inside doesn't get cold but if the outside is getting warm it can only be because the inside is getting cold - or at least should be.
I expect the defrost heater which should operate only briefly after each cooling cycle to melt any frost that has formed over the evaporator has, because of a fault, remained switched on causing the oven effect. This will force the compressor to work harder and cause the outside to be warmer than usual.
I suggest you contact the repair shop as soon as possible. The fridge will probably be cooler switched off and loaded with ice from the freezer or frozen cool-packs.
I doubt the internals of your fridge are easily accessible but if they are (safely) disconnecting the defrost heater could effect a temporary solution.
Aug 28, 2016 | Refrigerators
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
if chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
May 16, 2014 | Thetford Norcold RV Cooler/Freezer
Refrigerator is hot but the freezer is cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 12, 2013 | Sub-Zero 650 / O Bottom Freezer...
Lhave a rm 2601 rv refrigerator and when I cut it on the freezer coil gets warm instead of cold.Also it is making a gurdling noise. when I open the door to refrigerator the it has a ammonia bad...
Shut it off and get it checked. Ammonia is dangerous as I am sure you are aware. Ammonia smell is an indication of a leaking cooling unit. Time for a new fridge. Sorry.
Oct 14, 2011 | Dometic Rooftop RV Air Conditioner
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
I have a Dometic RV fridge that wont get cold. It is a model RM 2401. It easily lights on gas, the coils get hot and it makes a little gurgling noise but does not get cold. Can this be recharged?
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Jun 29, 2009 | Dometic RM2620 Refrigerator
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Not getting cool enough
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
Jun 28, 2008 | Dometic NDR 1292 Refrigerator
try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
Jun 23, 2008 | Dometic NDR 1292 Refrigerator
Dometic RM2852 Refrigerator Logo
610 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
