Question about Sebo Air Belt C3.1 Bagged Canister Vacuum
Switch dosn't turn on. is it switch or is it
Switch dosn't turn on. is it switch or is it plug?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
If you have changed the fuse in the plug and the wiring is ok there then it has to be the switch its self check the conections and clean if ness
Posted on Jul 27, 2010
My dyson won't turn on when plugged in ..seems problem with prongs on plug
It seems that it could be a problem with your power cord. I would start by checking to make sure it is good. If so, then check the switch next.
Mar 22, 2016 | Dyson DC07 Low Reach Vacuum Cleaner...
How to turn on everstar VC_356 vacuum
Could be, but many times the wire right be the plug breaks. Many users pull on the cord. Should pull on the plug instead. Pulling the cord and with a wiggle is worse.
Nov 10, 2014 | Vacuums
Water dosn't came out
Hi Kay. I know how frustrating no spray can be when you're ready to clean.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Mar 26, 2013 | Bissell 1697-7 Powersteamer Pro Deluxe...
My h2o mop will not allow any water flow the red light comes on after afrw minutes the green light comes on but there is no water or steam flowing out what can i do
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
Apr 13, 2011 | H2o TR220002 Steam Cleaner
It's plugged in but won't turn on?
Let's do some trouble shooting:
With it plugged in, do you see any lights on the control panel?
Miele also has a little device, that let's you 'park' the floor want in a neat little slot at the handle end of the machine-- and when it is plugged in there, the machine shuts off.
Finally there are switches on the top of the machine that control the speed of the machine-- what happens when you operate that switch-
The other switch turns it on and off-- Do you feel the switch snap when you push it?
Let us know what you find--
Mack B
Jan 20, 2011 | Miele S318 Bagged Canister Vacuum
My Heritage II just lost power in the middle of vacuuming. The switch will turn on but no power.??? What is wrong?
It could be the switch that has become defective (the 'feel' of the switch may be different, but needs to be checked with a meter). Another possibility is that the cord has developed a loose connection at or near the power plug. Turn the switch on and wiggle/push the cord near the plug. An intermittent connection is indicated by the motor turning on and off. If so, cut the plug from the cord (they are usually a molded device that can't be serviced) and install a replacement plug from a hardware store or home center. If the switch is determined to be bad, order a new one from an appliance parts store or vacuum repair center. Good luck!
Feb 20, 2010 | Kirby Heritage II Vacuum
Unit has power from Plug to unit. Current flows all the way to switch and switch seems to be ok but unit will not turn on. Wife says it was cutting on and off when moving it around. Checked conntec
you either have a bad switch oir you have a short in the cord.plug it in and turn it on then move the cord around from top to bottom and see if it acts up..if not tap on the switch afew times and if it cuts out then the switch is bad.try to plug it in in a couple of different outlets and see if it does the same thing.it could be a bad outlet.plug it in one thats pretty tight to push in and pull out.
Apr 29, 2009 | Vacuums
My Eureka Whirlwind vacuum on-off switch won't turn off
the power switch is bad. go to your local hardware store and buy a new power switch and replace it.
Mar 23, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Bissel 1695 - pump not turning on. Vacuum turns on
bad switch or connecter at switch or the pump is plugged
Feb 22, 2009 | Bissell 1695 PowerSteamer Vacuum
Sebo Air Belt C3.1 Bagged Canister Vacuum Logo
145 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
