Question about Apple iPhone Smartphone
Hithe bottom of my iphone touchscreen is not working. the hashkey(#) call button and star(*)keys line touch screen is not working. can anyone suggest me what i must do. If i update the os will it work.
    Problem Solver:
  • 39 Answers
He don"t work the display help please!
Posted on Jul 25, 2010
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
Hi, i have a iphone 8gb the last bottom line of the keypad is not working. when the phone ring i cannot pick up my call cause the touch screen bottom line is not working
It could be that the touchscreen plate of ur phone is messed up, u could have it fixed through apple support or go to a local repair shop.
Hope that'll help you..
Happy Holidays...
Dec 16, 2009 | Apple Cell Phones
Iphone touch screen is not working. Restored the phone from backup succesfully, but screen still doesn't work. Phone receives calls, etc., but can't unlock or answer calls because screen doesn't respond to...
Even though the iPhonemag-glass_10x10.gif is a device that is extremely convenient to have, it still can cause frustrations. Specifically, there may be times when the touch screen does not work properly.
There are various problems the iPhone touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Of course, it is possible that the entire screen works, but is simply slow. Regardless of the exact problem, there are ways to troubleshoot the iPhone to diagnose the real problem.
  1. tep 1 Remove the wiping cloth that came in the small black envelope along with the iPhone. Wipe the smudges or dust off the screen with this cloth. It is best to wipe in a circular motion.
  2. Step 2 Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating systemmag-glass_10x10.gif.
  3. Step 3 Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
  4. Step 4 If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
  5. Step 5 Press and hold the home button as well as the reset button on the top of the phone to turn the iPhone off. A red slider will appear. Slide it to the right to turn the phone off. Press again on the "Reset" button on the top to turn the phone back on.
  6. Step 6 Completely reset the iPhone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets and the Apple logo appears on the phone.
    • If you are using the iPhone in cold weather and wearing gloves, the iPhone will not react to the gloves as it will to the touch of a finger.
    • If the touchscreen is dirty, do not run the iPhone under water. Doing this will likely ruin the phone, but even if it doesn't, it will possibly make the phone run slower.
Nov 15, 2009 | Apple iPhone Smartphone
Right side of i touch screen non-reactive
Perform the under given steps to troubleshoot the issue:
(i) Clean the iPhone screen with the cleaning cloth that came in the box with the iPhone.
(ii) If you have a protective plastic sheet or film on the touchscreen, try removing it because it may be preventing the touchscreen from working properly.
(iii) The current application may not be responding (frozen), press and hold the Home button below the screen for at least 30 seconds, until the application you were using quits.
(iv) If that doesn't work, turn the iPhone off and turn it on again. Press and hold the Sleep/Wake button on the top of the iPhone for 30 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
(v) If the iPhone did not turn off, reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for a least 30 seconds, until the Apple logo appears.
If the issue persists then service will be required.
Sep 08, 2009 | Apple iPod touch
Ditto!
Hi. Hook it up to your PC. Run iTunes. On your left in the iTunes - find your iPhone. Click on it. My iPhone dialog will appear. There you will find buttons: Updates and Restore. Prior to pressing RESTORE button, check if you synchronized your CONTACTS with either Outlook (my suggestion) or any other addresse book. When you synchronized the contacts, click RESTORE. It will set your iPhone to the factory settings. |Check, if everything is working properly. Do the contact synchronization. If you still have an issue with the touchscreen - go for warranty exchange :) Hope this solves your problem
Aug 04, 2009 | Apple iPhone 3G
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
IPhone Touchscreen Partial Hypersensitivity
Have you fitted a screen protector, as this could be causing inadvertant screen touches. If not try a reset. Hold down the power key at the same time as the round home key until
phone powers down. Release buttons only when you see the apple logo,
then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back
up essential data ie contacts apps etc, then go to settings general and reset. Reset
all settings as a last resort. This will give you a fresh start and should sort out
the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Dec 21, 2008 | Apple iPhone 3G
Touchscreen offset
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
Feb 26, 2008 | Garmin StreetPilot C320 GPS Receiver
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Jan 12, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
251 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
