Question about Dell Latitude D800 Notebook
I have no sound on my computer, no volume app at bottom right of tool bar, and i can hit the volume button but it doesn;t seem to do anything, whenever i try to play a song with winamp 5 a pop-up appears with bad directsound driver error code 88780078. i go into winamp to that output thing and it gives me a primary sound driver and won;t apply, can someone help?
    Novelist:
    Scholar:
  • 85 Answers
Ok go into the control panelsystem properties and open the "Device Manager" then go to "Sound Video & Game controllers" section and highlight your sound card by clicking on it once and then hit "delete" on your keyboard or "right click" on it and choose “Uninstall” from the drop down menu and when it ask if your sure you want to remove this device ? choose “Yes” and when the uninstall is complete then reboot your computer and the sound card should reinstall itself
If it fails the install due to not being able to find the install files then you will need to either tell it where the files are located or if you do not know then you will need to go to the Dell website and download the driver and install it .. But either way you will need to uninstall and reinstall the driver to get it to work again..
Here is a link to save you some time: http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=3&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=LAT_PNT_PNT_D800&hidos=WW1&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False
Posted on Jul 16, 2010
Testimonial: "Thank YOU thank YOU! this was driving me nuts, you led me to the right place, a just had to do a few extra things (download) and it's fixed! I was on the verge of destroying my laptop and was getting really frustrated. the only noise it would make is the annoying beep from pop-up windows. But now i can actually listen to music! Thanks again. Shannon"
  • Darren Kessinger
    Darren Kessinger Jul 16, 2010
    NOTE: if you do not see your sound card listed in the "Sound Video & Game controllers" section then look for a section called "other devices" and there it might say "multimedia controller" and probably have a yellow mark on it... that is your sound card..
    Just follow same instructions above..
    If you can not find it at all anywhere in the device manager then it is probably disabled in the bios and you will need to hit the "F2" at boot up time and re-enable it..
    Hope this info helps
  • Dell Expert
  • 560 Answers
This is a very common problem with Windows 7 OS, it doesn't matter which laptop you are using..Get the help below..
http://microsoft-support-squad.blogspot.com/2012/06/fix-windows-7-low-volume-problem.html
Posted on Sep 28, 2012
打開控制面板,設置通訊選項中的聲音選項。
有更好的 惠普Pavilion DV4215TX筆記本電腦鍵盤
Posted on Jul 27, 2010
How do you fix the sound
Assuming youve checked every volume slider there is (the one in whatever program your using, the one on the bottom right corner of the screen by the clock, and the master volume.....
Thab go to your start button on the bottom left of the screen (where you normally access all your programs), there should be a little "search bar" on the bottom of that list. Type on "device manager", scroll down the list and locate your speakers, right click and than go to properties. First try "update driver", if that doesn't work than click "Uninstaller driver" and restart your computer. That should do it.
Dec 13, 2014 | Audio Players & Recorders
Tool bar moved t right and is large
Right click on the task bar (I assume you mean the bar that is typically at the bottom of your desktop?)
Make sure "Lock the Task bar" is not checked
Click on the border of the task bar
drag directly from where you clicked to the bottom
Adjust height accordingly
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
My son's Leapster Explorer suddenly has no sound. If you hit the increase sound button, nothing happens. If you hit the decrease button you see the volume bar on the bottom of the page. Do you know...
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
Jun 14, 2011 | LeapFrog Leapster Explorer Learning Game...
My acer netbook is stuck on mute
if the little x over the volume bar is still stuck after moving it up you may have to hit the function key (fn) on your laptop and hit one of the F1-F12 KEYS that look like a mute or volume symbol also there should be a mute button on the laptop itself. if all that fails. go to (xp) right click on my computer -device manager-and see if you have a red or yellow x over your sound sound devices (win vista or 7) go to computer, sys prop on the top then device manager. if you see any of htose yellow or red warnings you will need to re-download the audio drivers from acer website Let me know if this helped.
-Brian
Mar 19, 2011 | Acer Aspire One PC Notebook
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
No sound when computer is being shut down or playing music on windows media player. button next to power button not lite up. push mute button back off still cannot get a sound.
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Sep 12, 2010 | Dell Latitude D600 Notebook
No sound card driver no sound audio
Try this:
Go to Start->Settings->Control Panel->Adminstrative Tools->Services
Then locate in the list of services "Windows Audio". Open this service
If this service is showing with a Startup type set to Disabled then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
If this service is showing with a Startup type set to Manual then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
Next Go to Start->Settings->Control Panel->Sounds and Audio Devices then select the Volume Tab then put a tick in the box marked "Place Volume Icon in the Task Bar" then click apply.
With a bit of luck and following wind you should now have your sound restored.
Good luck
Apr 20, 2010 | HP (400745-001) Sound Card
Acer speaker?
There are two possible problems here. (1). The volume control on your monitor is turned down. With the button on the front of your monitor, find the menu/option button, and look for volume control (2) The volume coming out of your computer is low. Double click on the speaker at the bottom right of your screen, located on the start bar. Use the sliders to change the volume. This should fixya up.
Good Luck!
Dec 12, 2008 | Computers & Internet
Volume button
go to start menu -> control panel -> sound and audio devices. you will find volume control. or another method is just click on the volume icon which is located at the right bottom of your windows desktop.
Jun 20, 2008 | Computers & Internet
Loss of volume button
click on start then go to setting then control panel in control panel go to sound and audio devices i n that you will see volume tab in volume ther is option called place volume icon in the task bar just select taht and apply it it will show spk icon on your task bar but be sure that your sound card is properly installed. pls get me back if you need further assistence. bye
Sep 24, 2007 | HP Pavilion a815n (PS512AA) PC Desktop
Dell Latitude D800 Notebook Logo
443 people viewed this question
Alun Cox
